Siemens Logo query
gregblack
Jul 2004
I have a Siemens Logo 230RC which seems easy enough to use (despite minimal online help and a laughable "tutorial") although one aspect has me baffled:
I1
-] [------------------------------------------[T1]
T1 T2
Trying to drag and drop a vertical joiner from the right of T2 up to the horizontal joiner above, I get an "incompatible connectors" message.
Any help appreciated.
Hi greyblack,
I'm using logosoft comfort 4.0.
For the vertical connector you should draw the line to the connection point of T1 at the right. Then het draws the line vertical.
Best regards
Ed
Greg,
I'm not familiar with the Siemens at all, but I think I've seen in some others you may have to put a horizontal connector after the NC T2 before you can drop in the verticle connector. Hope this helps.
Bob
Hi all, First, thank you for reading the thread. So I had a task as the following: An up-counter must be programmed as part of a batch-counting...
286
Hi Lads, I want to implement a flood prevention system with my domestic water pump. The intention is to have the water pump cut off on a daily...
1,077
We need a Really Simple and Cheap controller that has a display or a Web Interface where we can change some set points. We were thinking about a...
1,040
hello i have LOGO! 12/24RCE and i am looking for a schematics of electronic board. Or if someone know what is the burned component on the photo.
1,408
Hi, I'm no expert in PID regulating so I need some advise. I have a VFD controlled deepwaterpump that is maintaining the pressure in a closed...
24
11,905
