CP340 or CP 341 communication processor
aprilchu
Sep 2004
26
As i know , a communication processor and modbus frive can implement Modbus on CPU 314 .
Then what is a difference between CP341 serial communication processor and CP340 communication processor??
Thx. :p
still asking CP 314 and CP 340
Does it mean that CP341 can be a Master AND Slave at the same mod. ?
But, CP 340 just be either Master or Slave ?
Moreover, I found that Siemens has a product (6ES7 870-1AA01-0YA0).
Its description is Simatic S7, Modbus master v3.1 .
Does it mean that it just be a Master ???
Thx~~
I mean CP 340 does not support Modbus at all.
CP 341 can be used as Master or Slave.
6ES7 870-1AA01-0YA0 - master driver
6ES7 870-1AB01-0YA0 - slave driver
- it also supports DF1
Does it surffice?
Why CP340 don't need to write a read command?
HI!
I have a program made a serial port communication CP340 and peripheral equipment, discovery and DP different is that it does not need to send to READ instructions, called directly READ FROM CP340 can READ data, who can tell me why?
You might want to create a new thread. Piggybacking on a 11 year old thread seems a little bit silly.
While you are at it, try to elaborate your question. It does not make much sense to me.
Hallo, I have Tia Portal V16 and I'm upgrading an older machine. That machine has a component running on rs232. The machine has still the old...
987
Hi all, i have a module from b&r automation and i am want to get the data from it, but the com port is already taken. Is it possible to monitor...
1,166
Hi, I am planning to use the 300 series in redundacy by using two cpus, and IM153 modules in Profibus DP. I am having some problems with my...
1,196
Hi, been looking everywhere for this info but cant find it. Does anyone know if the CP340 RS232 card supplies 5v to Pin 9. Thanks
1,425
Hello, We have a Sartorius CP scale connected via RS232 to the PLC. All was working well but when the scale was replaced with a newer version...
2,556
