RSLinx
wolverine1981
Oct 2009
Chicago, Illinois
194
Good Morning,
I have a question. I am attempting to connect with a CompactLogix using RsLogix 5000 to upload the program, for some reason RSLinx is not loading up.
I have attempted to open it from the file, Start Menu, RSLogix to no luck. I am using windows 10 64bit. Any one have this problem before?
Tom
wolverine1981 said:
...I am attempting to connect with a CompactLogix using RsLogix 5000 to upload the program, for some reason RSLinx is not loading up.
I have attempted to open it from the file, Start Menu, RSLogix to no luck. I am using windows 10 64bit. Any one have this problem before?...
Hi Tom,
Just to be clear, it's RSLinx Classic that is not opening and RSLogix 5000 is OK?
If so - the most likely cause is that RSLinx Classic is set to "Run as a Service" and needs to be changed to "Run as an Application". When running as a service the graphical user interface (GUI) is not available and will not open.
Go to...
Start>Programs>Rockwell Software>RSLinx>RSLinx Classic Launch Control Panel
RSLinx Classic Launch Control Panel > click Stop
Uncheck Always Run As Service
Click Start
RSLinx Classic should now run as an application and the GUI should open.
If it's not that then tell us which version of RSLinx Classic you are using (always do that in your first post anyway) and there may be other things to suggest.
Regards,
George
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
184
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
230
Anyone have issues with RSLinx being very slow to open. It sometimes will say "Checking Activation" at the bottom for what seems like an...
145
I need to support some old data collection that is running on Excel, but I need to get it running on LibreOffice. The following statement works...
85
Hey All, I am sorry to ask this, but i still gotta do it. What happens if I close RS linx? Will it cause network interruption and PLCs will lose...
155
