GE Fanuc 351
tarik1978
Mar 2010
casablanca
716
[/IMG]
Can I use a usb to serial converter to connect to the cpu port 1 (RJ11)?
And also which software do I need?
If you are currently using one for programming through either the port on the power supply or Port 2 on the CPU module, it should also work on Port 1.
The software currently supported by GE is called Proficy Machine Edition. Earlier programming packages were called VersaPro (Windows) and Logicmaster 90 (DOS).
The customer told me that probably the program in PLC is lost (the machine was many days in shutdown).
he gives me the backup program, but I dont know if it's the correct one.
the program has some extensions .EXP, .PDT . STE .AI .AQ.....
the program is attached.
Thanks Steve for the info
I have a proficy machine edition 8.6, is it possible to importe this program?
when imorting I got this error:
Error 10456: Error importing logic file.
I'm working on a 90-30 PLC which keep losing its program everytime it is powered down. We first figured it must be a battery issue, so we tried...
1,307
Hi, could someone do a favor for me: I have a program in logicmaster 90 writen in SFC When I try to import program in PME I got an error, logic...
3,129
The PLC has a program in it that possibly programmed using LOGIC master, which I do not have. Prior purchasing "Proficy ME 8.5" I talked to GE...
3,022
I am setting up a bench practice unit consisting of a 5 slot rack (IC693CHS397C), POWER SUPPLY IC693PWR330C, cpu 351,and one input and one output...
3,850
I have a CNC cutting equipment, all the components are Fanuc from the CNC CPU A02B-0307-B822, a PLC AIF01A and a panel i, on the panel i (operator...
108
