Connected components workbench temperature control
avlgeneral
Apr 2016
Ontario
Hi guys, very new here so apologies in advance for poor forum use.
I just need some advice to kickstart a project ive been given, some basic "how to" and "where to" start in the program.
I've purchased a Micro850 with expansion AI and AO cards and plan to use connected components workbench (obviously) to program a temperature control loop.
It's a generator package, where a 4-20mA temp signal will be the feedback for an intake, discharge and recirculation louvers along with a fan controlled by a VFD to control the temperature and keep it at a constant temp. The PLC will only be used to control the temperature via louvers and fan.
The set up will be, the intake and discharge louvers will modulate according to the temp, the re-circulation louvers will simply open and close. Recirc will be open along with discharge and intake being closed when its cold (to increase the package temperature) then when up to temperature the recirc louvers will close and the intake and discharge louvers will modulate accordingly.
When i say intake and discharge i mean to the container holding the generator.
How would one start this process? Would you use a PID function block or am i over thinking it?
I realise this is a basic-ish kind of set up, but i havent used PLC programming software in quite some time. Any info on connected components work bench would be greatly appreciated.
was trying to use Connected Components to connect to a 525 drive via usb with the face off but can't seem to connect to it. the screen lights up...
790
So I'm using CCW to program a panel view and this is not my first I have done many. My Problem is I get an error message that I have never seen...
497
How do you expand a branch in connected components workbench. Example i want to add an interlock around more than one contact. Most software you...
1,282
I’m working on a conveyor project for work. We’re trying to install a few diverts to carry product directly to one of two trailer doors. I have...
1,054
I cannot get CCW to add a controller, i keep getting a error message saying that the device is not authorized. This happens with any model and...
1,373
