Siemens WinCC (TIA Portal) v14 Runtime Issue with edited Graphics in photoshop!
DenZ_P
Jun 2016
SomeWhere
64
Hello Everyone,
I am configuring now a SCADA and needs help with my edited graphics i have edited in Photoshop CS6. Why did I edit a graphic that came from WinCC in Photoshop? That is another issue about WinCC about rotating graphics but that should be discussed in another thread.
Anyways, now this edited graphics I have is having a filled solid colored background of black even though i have put the fill pattern to transparent. Really need help with this issue.Please see attach files for the screenshot of the Runtime View and the Graphic in Project View. thanks!
It seems that it is in the RunTime settings of my TIA Portal that I have recently tried to change the Runtime design setting to WinCC Classic instead of using the default design which is WinCC Light.
When I set it up to WinCC light default and checked the default setting it is now already ok.
I thought I was nearly finished on this TIA Portal/s7-1212C project (famous last words)... Up until now, I'd developed the PLC/HMI such that the...
1,556
Hi, I have a HMI which is a KTP1200 Basic. Let's suppose USER03 is logged in. How do I create a simple "Lock Screen" that appears if the screen...
673
Hi, At the moment, If the user fails to provide a valid username/password, the image attached appears "Invalid password or user name. Logon has...
1,573
On my HMI (KTP1200), I've got this button "Generate Report", which generates a report (CSV) when it's pressed. (see pic) While it's being...
546
I’m a bit stuck on HMI (KTP-1200) programming… See the picture attached. The PASS or FAIL box should only appear when the toggle switch is...
1,072
