Cannot access Mitsubishi GOT Simple over Ethernet
doomsword
Aug 2016
Zagreb
201
I have very basic problem which I can't solve for some time already and it's driving me nuts.
So my system consists of GOT Simple 2107-WBTD and FR-A820 frequency inverter. I connected them over RS485 connection, works fine (using built in RS485 on inverter and GOT Simple).
Problem is that I can't connect to GS to download a program on it over Ethernet (UDP) cable! I can access GS only through USB connection, so I can download a program on it.
I can ping GS. GS can ping my laptop. Port settings are OK. Cable works. There's no switch. And all the time I'm getting timeouts, I'm attaching a pic of it.
Any idea what is broken? It worked first few times when I tried to access GS over Ethernet, but now it doesn't work at all.
It's important since we plan to connect GS and inverter using CC-Link IE Field Basic, which is Ethernet based protocol, inverter with IE Field Basic will be available very soon, I don't want any troubles with Ethernet.
Hello Friends I have a backup that I am trying t open in mi PC (RSLogix 17.01) and I get this message. I have read many posts and done many...
168
Hi All, Newbie questions but I have two of them!: 1. I am unable to toggle the bit on I:0 (it keeps at 0). If I go into the data file and...
2,434
Hi, I want to connect the Intouch and MS SQL Server. But now I cannot access the SQL Server into MS SQL Server, the message was showing Invalid...
7,138
Wonderware 7.0 CTIos 5.2 Running as a service. Suitelink also running as a service Windows XP. I keep getting the Wonderware Cannot Access...
3,940
Hi, I setup Smartserver on my wincc. I can access remotely but i cannot click or control anything.. On the mouse cursor its written no-input...
2,042
