WINCC SCADA Remote access cannot click
NiCeBoY
Jul 2011
Narre-Warren
37
I setup Smartserver on my wincc.
I can access remotely but i cannot click or control anything..
On the mouse cursor its written no-input.
Anyone have an idea how to fix this? any configuration somewhere for that.. i tried everything for hours, but cannot get it fixed..
cheers
In the Sm@rtserver options on the panel, where you enter the settings, there are 2 lines for passwords. Just next to the field where you enter the password there's a selectionbox. DO NOT select that box. It makes that password read only, meaning you won't be able to control the panel.
By defaul the 100 password is read only. You need to change it.
Another way the no input can appear is when someone is using the panel locally, then the remote user is in View-only mode.
The selection boxes are not ticked, this is for sure.
Tomorrow i'll try not to use the local computer and then will see it it works...
because i remember it was working before..
thanks mate
We have experienced this before.
For some reason the local user keeps being 'active'.
Some times it can be resolved by stopping and restarting the Sm@rtServer.
Other times it needs a reboot.
We have yet to find out what causes this.
Is it possible to connect a PC with running WinCC Advanced or Unified to a siemens PLC such as S7-1200 across different subnets? The computers can...
92
We are using wincc scada WinCC system software V7.5 SP2 , connected to few plc . Past 3 weeks we getting this alarm continously when we checked...
84
when i tried to go online, why its showing lie this
91
I am utilizing both HMI and SCADA for my project. Both HMI and SCADA have identical tags. When I modify the tag value on HMI, it is reflected in...
156
Got a new project using WinCC SCADA (V7.5 SP2) - the PLC is an ET200-SP, I've never had to communicate with one of these before (done plenty of...
2,408
