plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old June 16th, 2017, 05:15 AM   #1
DarrenG
United Kingdom
DarrenG is offline
FactoryTalk View Studio - SE w/PlantPax Setup
Hi folks,
I'm beginning to pull my hair out over this so if someone could shed some light on what's going on I'd be grateful.
We bought FactoryTalk View Studio SE Edition with PlantPax a few months ago and I've tried to import all the PlantPax images and global objects etc a few times to get the hang of it before we do training but I must be doing something wrong because the global objects and displays are just full of boxes or lines or question marks.
The instructions say you must import the image files first, then global objects followed by whatever faceplates/displays you need at the time and then macros. Simple right? Apparently not, I've done this at least 5 times and I'm either losing the plot or I'm missing something...I'm definitely not ruling out the possibility that I'm losing the plot either.
There are multiple folders within the PlantPax add on that contain images, global objects etc so at first I tried just importing the files from the 'process objects library' folder to see if that worked as it seems to be the main one. In that folder it had images, let's say around 20 global objects pages, a few faceplates/displays and a macro I believe so I thought surely all the files needed to display the global objects are in this one folder. That didn't work so I went on to import absolutely every image from every folder and the global objects and displays will still not display correctly.
Has anyone else come across this before? I will try upload some pics but in the past any pics I've uploaded have been poor quality for some reason :/
Old June 16th, 2017, 06:38 AM   #2
jkerekes
United States
jkerekes is offline
jkerekes's Avatar
I've used PlantPAx and haven't seen that issue. What version of SE and what version of PlantPAx?
__________________
John
Old June 16th, 2017, 06:44 AM   #3
DarrenG
United Kingdom
DarrenG is offline
SE version 9 and PlantPAx version 3.5-06
Old June 16th, 2017, 07:04 AM   #4
jkerekes
United States
jkerekes is offline
jkerekes's Avatar
Do these question marks show up in the development environment without a test run?
__________________
John
Old June 16th, 2017, 07:23 AM   #5
DarrenG
United Kingdom
DarrenG is offline
Yes, I just copied two items at random and this is what they look like when testing the display.
Old June 16th, 2017, 07:26 AM   #6
jkerekes
United States
jkerekes is offline
jkerekes's Avatar
But you need to have the corresponding AOI in your program and configure the parameters of the PlantPAx grafix objects before they will work.
__________________
John
Old June 16th, 2017, 07:53 AM   #7
DarrenG
United Kingdom
DarrenG is offline
What do you mean configure the parameters of the graphics? In the picture in my original post 'global object1' you can barely see what anything is, that can't be right surely? I don't see how not having the correct AOI in the code should have that much of an impact on the graphics, or for the pump in my last post to display as just a circular line, unless I'm mistaken. Sure it might not work correctly but it just doesn't seem right, it looks as if I'm missing image files or something but I've imported everything that was in the PlantPAx folder. Did the global objects look like that when you used them?
Old June 16th, 2017, 08:04 AM   #8
rdrast
United States
rdrast is offline
rdrast's Avatar
Quote:
You are mistaken.
The graphics absolutely MUST reference valid tags in the PLC, or everything breaks.
And make a VM copy of your development environment there, and use only that for your SE/PAX/PLC work. Otherwise, if you upgrade ANY Rockwell component or software, even completely unrelated, it will completely break your Studio application.
__________________
How to ask questions the SMART Way!
Look First, Ask Second!
Old June 16th, 2017, 09:27 AM   #9
DarrenG
United Kingdom
DarrenG is offline
I think we might be talking about two separate things so I just want to make sure. Thanks to you both for your help so far, I'm just not used to this package at all at all and if we are talking about the same thing then I'm baffled.
The pictures I originally posted are from the global objects library pages which should be copied into the development space and then assigned tags. What's confusing me is that you're saying they need to be assigned tags to work, which is fair enough in the development space, but in the library they're not displaying correctly (or not what I'm used to anyway) to begin with making it impossible to know what I want to use from the very get go as I can't see what they are, if that makes sense?
It's the equivalent of going to the default symbol library to select a tank or a pipe or whatever and the tank/pipe just being a square box with a question mark in the middle. I can understand what you mean about it not working without a tag during runtime, but I can't get my head around why the graphics would not show a finished representation of what the item should be in the library.
The pic below is of the 'Process Interlock Objects' page in the library where I'm supposed to go and decide what I want to use in the project and I genuinely haven't a clue what anything in there is or what I may or may not want to use because everything is either a tick or a question mark.
Old June 16th, 2017, 09:31 AM   #10
DarrenG
United Kingdom
DarrenG is offline
Right I did some digging on the internet and found a picture of what the library should look like. The title up on the top left doesn't display correctly in my library nor does any of the text for that matter so there is definitely something not quite right.
Old June 16th, 2017, 09:36 AM   #11
labeledas
Canada
labeledas is offline
labeledas's Avatar
just out of curiosity what language is your application setup for US English or UK I have seen some strange things when I set my apps up for Canadian English and used prebuilt AOI's
Old June 16th, 2017, 09:55 AM   #12
jkerekes
United States
jkerekes is offline
jkerekes's Avatar
Are you test running the global display?
__________________
John
Old June 16th, 2017, 10:02 AM   #13
DarrenG
United Kingdom
DarrenG is offline
labeledas: It's set up for UK English, I think that was the default language.
jkerekes: I'm just trying to see what is actually in the PlantPAx library and what makes it different to the default FactoryTalk symbol library/why we bought it. I'm not really concerned with test running anything at the moment, just seeing what's available before using it for a project, but it seems like the global objects aren't displaying correctly, and I'm trying to figure out why or if anyone has had something similar happen before.
Old June 16th, 2017, 10:06 AM   #14
labeledas
Canada
labeledas's Avatar
Can you try to set up a new application for US English and import and see if they work, like I said I have seen weird issues using Canadian English using objects built with US English, shouldn't make a difference but I have seen it happen
Old June 16th, 2017, 10:09 AM   #15
DarrenG
United Kingdom
DarrenG is offline
Yeah no worries I'll try that now and see what happens, thanks! I'll let you know how that goes shortly.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
VNC Server FactoryTalk View SE elmatador LIVE PLC Questions And Answers 3 March 21st, 2017 07:09 PM
FactoryTalk View Studio SE send value to a plc simulation1337 LIVE PLC Questions And Answers 6 July 26th, 2016 02:22 PM
Right Click Event FactoryTalk View SE zacslade LIVE PLC Questions And Answers 2 October 23rd, 2015 11:01 AM
FactoryTalk View Studio install problem xzen LIVE PLC Questions And Answers 0 October 9th, 2013 07:08 AM
FactoryTalk View Studio Communcations Setup (V7.0) fantom11 LIVE PLC Questions And Answers 2 August 16th, 2013 11:54 AM
