About PLC loading and emulator 5000
timcph2008
Jul 2015
United State
33
Hello guys,
Recently I am playing with AB rslogix emulator 5000. Then some question comes up on my mind.
The emulator performance depends on the computer CPU right? so there is no limitation of memory, maximum tags something like that in the emulator? How do I simulate the real PLC without these factor?
I wouldnt know what point is the point to add more Processor correct?
How do I know what is the best loading for the processor(I do not have specific processor in use, lets say in general)? Can I simulate that? or I need to calculate with the specification of the processor?
Thank you guys!
All you have to do is change the processor type to the actual CPU you will be using and look under the memory tab in processor properties to see the memory loading.
Hi everyone, I want to upload the program from my CPU317TF-2 DP to my PC via connecting to CP 343-1 Advanced since it has LAN ports and the CPU...
189
Hey guys, I've a requirement that a two different PLC program should work in same system depending upon user input. Consider Program A is used...
1,947
So i have an allen bradley rack (2080-LC50-24QWB), i have it connected through ethernet. I dont have an offline program so im trying to upload...
706
Got an old machine with a IC610CPU104 CPU. A bit of research told me this is the same as DL305 so DirectSoft from AutomationDirect should work...
2,102
Hello, I am attempting to download a program someone else created to an existing PLC (1769-L24ER-QB1B CompactLogix5370 Controller). However, when...
1,111
