plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old January 23rd, 2018, 07:58 AM   #1
rguimond
Canada
rguimond is offline
Disposable (cheap) wireless temperature probe
I'm trying to predict when a peat moss pile is likely to undergo spontaneously combustion. Currently, it's a full-time job for someone to punch holes in piles and insert probes to take periodic temperature readings. In addition to being cumbersome and time-consuming, the holes introduce oxygen, which tends to escalate temperature increase.
I was hoping to find a source of cheap wireless temperature transmitters. During processing, it's likely that most will be recovered, but it's also likely that a lot could be damaged.
These could be inserted as deep as 10' into piles of harvested sphagnum moss. Bluetooth would probably work, but 433MHz could also work.
Something like a AcuRite 06002RM Wireless Temperature and Humidity Sensor would be OK, but it will be expensive to have them in 1000+ piles and there's also a possibility that the reader will pick up signals from adjacent piles.
Something that could be assigned a unique address would be ideal.
I was thinking that whatever we use could be inserted into a sealed PVC pipe for protection from the elements and to allow easy retrieval before the pile is transferred by simply pulling out the pipe.
__________________
"If you can't measure it, you can't manage it!"
Old January 23rd, 2018, 09:57 AM   #2
RDS
United States
RDS is offline
RDS's Avatar
I have heard of temperature sensors that are embedded in concrete to monitor the cure temperature, obviously throwaways. Try here for a start:
http://www.madgetech.com/data-logger.../concrete.html
Old January 23rd, 2018, 10:36 AM   #3
boneless
United States
boneless is offline
I think you need to define cheap? $20 bucks for a wireless sensor is pretty cheap imo, but if you multiply that by 1000, you are looking at a $20,000 bill.
If you need that many, I think you could be developing (having developed) your own sensors.
At my home I am using Xiaomi sensors using Zigbee (2.4GHz I believe). They work great. They daisy-chain wirelessly. They are made for the Chinese market, but I got them working in my home automation system.
They don't seem to have any IP rating, but pretty sure they would still work in an ABS box.
Not the perfect solution, but I think it would be worth a try?
Old January 23rd, 2018, 03:05 PM   #4
arlenjacobs
Canada
arlenjacobs is offline
My guess is that you'll have a tough time finding the right wireless sensor; if any could work at 10' (3 metres) deep.
  • RF frequency
  • power of the transmitter
  • how wet is the moss
  • depth of the transmitter
Is the moss wet? Water kills RF very quickly. Within 1/2 meter depth you'll get high loss of signal. I doubt that AcuRite could transmit very far through wet moss; too low of power. Who knows if 433MHz is the best frequency.
You may be best off with your manual temperature readings.
Or, could you leave a 10' pole there? Sensor at one end and the transmitter at the other?
Don't know. Sounds like a tough problem.
Old January 23rd, 2018, 03:27 PM   #5
DBLD99
United States
DBLD99 is offline
We have used these for grain piles. Can't remember price though.
https://www.extrongrain.com/wireless...rature-probes/
Old January 23rd, 2018, 03:28 PM   #6
mk42
United States
mk42 is offline
If that Acurite sensor is too expensive at $13 bucks a pop, I don't think you'll find what you're looking for. Maybe you can get massive discounts for buying 1000 at a time, but I dunno. I think you'll fail at the funding stage, before it even makes sense to worry about the engineering problems like wireless signal strength.
Old January 23rd, 2018, 03:50 PM   #7
spaderkung
Sweden
spaderkung is offline
Is the purpose to save the one pile that burns or the rest of them?
__________________
Jon Bolmstedt, Inspired Automatician.
Old January 23rd, 2018, 07:37 PM   #8
rguimond
Canada
rguimond is offline
Quote:
Actually, the purpose is to predict when a pile will likely ignite so that it can be selected for immediate processing.
I guess saving adjacent piles will be a side benefit
__________________
Old January 23rd, 2018, 07:45 PM   #9
rguimond
Canada
rguimond is offline
Quote:
  • RF frequency
I expect this will be a challenge, but definitely worth it if it'll work.
I'll be testing various devices in an actual pile in a couple weeks. 2.4GHz and higher will undoubtedly be affected considerably if the moss is wet (it's never "sloppy-wet", and it's harvested when fairly dry) or if it's sheathed in an icy layer (like it is now). I have a 433MHz temperature and wind speed transmitter that I'll bury in a pile to see if the receiver will pick it up. I suspect it will, but I'll be sure to share the results. The problem with the 433MHz devices is that there are limited "channels".
Interestingly, we had a fire yesterday in a pile that was covered with 6-8" of ice and the ambient temperature was about -15C.
__________________
Old January 23rd, 2018, 07:47 PM   #10
rguimond
Canada
rguimond is offline
Could be feasible.
__________________
Old January 23rd, 2018, 07:49 PM   #11
rguimond
Canada
rguimond is offline
Probably worth a shot, but I'd have to come up with a way to provide power to the gateways they require. We're looking at several 200+ acre sites...
__________________
Old January 24th, 2018, 05:28 AM   #12
Saffa
New Zealand
Saffa is offline
Is the high temperature noticeable from the surface? I know you say you have to stick the probe in, but what about using thermal imaging?
Still a manual job, but someone could just walk around with the camera scanning for a high temp.
Although if this happens under a layer of ice...
Canada sounds dangerous! Exploding frozen moss is not a hazard I've encountered before
Old January 24th, 2018, 06:33 AM   #13
BryanG
United Kingdom
BryanG is offline
Following on from what Saffa said. If the stuff is under a pile of snow you won't see a high temperature, but I would expect that there would be a differential between the too hot pile and a normal pile. Look for the ones that are different.
Otherwise, as detecting from the top is an issue, how about embedding permanent sensors underneath the piles. No need for disposable and they should see the too hot temperatures whatever the weather.
Old January 24th, 2018, 09:20 AM   #14
lfe
France
lfe is offline
Time ago I worked with a kiln that served to determine the fire resistance of walls, doors and various materials.
The system recorded the temperature in several points and the test ended when some probes reached a certain temperature.
Many 3mm diameter thermocouple probes were used similar to this one. in both sides of the test wall. They were reused until they broke and it did not take much effort to mount the experiment.
Old January 24th, 2018, 01:55 PM   #15
Toine
Netherlands
Toine is offline
That seems at least partly feasible to me: stick this in a 10' PVC or metal pipe, add some glue to keep moist and dirt out and you are done. One could make a few hundred in a single day. Only downside: it is not wireless. If wireless is a hard requirement, then a battery powered transmitter would have to be added to the connector end of the PVC pipe to sit outside of the pile. With a transmitter the complexity goes up, and with that required time and thus costs.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
How Well Do You Really Know Thermocouples Archie LIVE PLC Questions And Answers 35 October 14th, 2016 11:21 AM
Temperature transmitter cheap cornbread LIVE PLC Questions And Answers 7 August 2nd, 2013 08:51 AM
Ethernet Temperature Probe swapped LIVE PLC Questions And Answers 7 January 17th, 2013 01:26 AM
Wireless Temperature Freak LIVE PLC Questions And Answers 10 March 20th, 2009 10:00 AM
Cheap Wireless HMI Vetteboy LIVE PLC Questions And Answers 9 May 8th, 2003 03:57 PM
