TIA PUT and GET ? or Other way ?
userxyz
May 2002
any
2,768
Hello,
I wanna communicate between 2 1500 CPU's.
I tried the old fashion way.
Made a project with 2 1500 CPU's.
Both CPU's enabled the Put & Get:
Connected both with ID 100:
PUT and GET functions only in PLC_1:
SEND and RECEIVE PLC_1:
SEND and RECEIVE PLC_2:
So here I'm not receiving the data that is PUT from PLC_1...
What could be the cause ?
I do not have errors and status is alternating between 0 and 25 (processing). So verything seems normal, but doesn't work...
Any ideas ?
Thanks in advance,
Kind regards,
Gerry
I don't think you can do both at the same time. I usually start the requirement for the GET, and use the DONE bit to start the PUT.
Let me see if I can get you a screenshot.
Edit: here you go. Alternatively, you could just use the inverted clock signal for the second one. But you should be looking for errors as well.
Tnx
Thanks.
I used M0.0 and M0.5, 2 different clock bits to avoid same cycle but still not working well. But I agree that using NDR is much better programmation. But for a quick test I used 2 different clock pulses.
Kind regards,
Gerry
What if you try blocking the first and just do the second?
What does the online connection say, does it have errors?
Did you download the connection to both PLCs?
Something is wrong with the PUT config
Thanks for the replies,
Sonething is wrong with the PUT, I tried the GET and PUT induvidual before I write something with NDR usage.
GET works,
PUT doesn't, and the config is not right either...
Found, I had several connections ID's, mismatching.
Thanks L D[AR2,P#0.0] for the alternate toggeling of data tip
Context: PLC= S7-1212C, HMI=KTP1200 Basic. Hi again, When the "REPORT" button is pressed (on a different screen), it takes the operator to the...
665
Hi, I'm not sure how to do this... Basically, I want to restrict the user input values for this tag to be in the range 20.001 to 25.0. I...
17
1,632
See the attached image. The Datalog should be created when I press Report_Button_Pressed on the HMI. This image is taken when I pressed the...
1,100
For the project I'm doing, the operator has to enter a string of 7 alphanumeric characters. This represents the unique part number. For now, the...
19
2,402
Good day, everyone, We're trying to establish an S7 connection on ethernet between an S7-400 CPU and a new S7-1200 CPU (which is defined as slave...
2,627
