New PVP1000 (800x600) Font Issues
DaDaDadeo
Feb 2018
New York State
92
Until recently, the PVP700 and PVP1000 projects were the same 600x480 resolution. The new PVP1000s are now 800x600. Has anyone been challenged with using screen selection lists or control lists in the new PVP1000s? Editing the screens is difficult since the runtime cannot be tested correctly on the desktop. The results must be verified by downloading the application to the panel. This is time consuming or sometimes impossible without the hardware.
An example is when a control list will display 15 lines on the desktop. However, the panel may only show 10 lines and the font is displayed much larger than in the editing window. This is challenge when lining a list up with some other objects we use for highlighting purposes.
I tried changing the desktop resolution with no success.
I also know there is an anomaly where the alarm list fonts are way too big when saving a runtime application in version 8 when using Studio version 9. The sure to this does not resolve the control list font issue
The only problem I've experienced is the font conversion results are too small, requiring me too manually change it (Or exporting and editing in XML). And I haven't had the alarm list fonts problem either, I use v9 to create v8 apps all the time. I am testing the app on a 4K laptop display.
Folks. I have used 9300-ENA and 1783-NATR modules for PLC to plant network connections. PLC to PLC connections and the like. I'm thinking it...
1,667
Hi guys and gals. I am having trouble with an Allen Bradley Panelview Plus 1000 shutting down every so often due to a "RSVCHost encountered a...
1,486
As above, new PVP1000 with 2711-RN6 module. Converting a small project over from a PV1000C. Anyway, my config is as follows--PVP1000 with DH+ to...
2,717
I have been using two of these HMIs on two sites with similar projects but developed separately. Now i want to use screens from one on the other...
343
Is there a way to choose the base font in ME. Text in the Arial Unicode MS which is the default font on my FTVS doesnt show up properly on a...
680
