NATR for VNC on PVP1000???
PLC Pie Guy
Jun 2013
Halifax
1,144
Folks.
I have used 9300-ENA and 1783-NATR modules for PLC to plant network connections. PLC to PLC connections and the like.
I'm thinking it should work, but I'm wondering about using the NATR simply to look at 2 PanelViews via VNC.
I have a large oven with 3 PVP1000 aboard, 2 of them are on the machine network. Rather than move them over to the plant network, which would involve running cables and modifying the application slightly, could I simply put the NATR module somewhere on my machine network and translate 2 of the machine IPs to Plant IPs? I'm thinking if I were to set the private port IP as the gateway address for the PVP1000 it should work........ Maybeo_O
Thanks for any input given.
I’m assuming that the hmi’s go to a switch first. To answer your question, yes it should work. I have a couple systems that hook to the plant network via NATR. I have connected successfully via tight vnc to the hmi’s from the plant network. I do believe a custom rule needs to be setup in the NATR to allow the vnc to connect. I’ll see if I can find what I did to make it work. I think I have a screen shot somewhere.
If I remember correctly you also need to add a rule for port 5900 to pass VNC traffic in the NATR. But it is while ago I worked with those things.
In regards to gateway address. You need to set the gateway address on your devices on the private side (pvp) to whatever the private side ip address of the NATR is.
Good morning Folks. I've been trying to get this to work but something isn't adding up. I have a basic system that consists of a private...
361
Is it possible to gather OPC data through a 1783-NATR? Searching around, it sounds like OPC data might be blocked by any NAT... Is there any work...
248
Good morning all, I have a project that has quite a few NATRs to configure. I would like to modify the generated backup config file because I...
437
For reasons, we have a 5370 CompactLogix (the kind with two ethernet ports that can't do dual IP) that needs to talk to two public networks...
430
I am trying to communicating with other PLCs on a public network from a CompactLogix PLC on a private network. I have installed at 1783-NATR...
557
