Boiler feedwater DP(kPa) to flow(m3/hr) calculation
bfranklin
Sep 2012
Alberta
125
All,
My client is looking to have me calculate the boiler feed water differential pressure in kPa to and actual flowrate in m3/hr.
Once the actual flow rate is derived, the flow rate goes into a custom function block which will get pressure and temperature (density) compensated.
The current conditions are:
DP: 42 kPa
Orfice ID: 40.4241mm
Pipe ID: 76.2mm
Control system:
Control logix L74 Version 20
HMI: Factory Talk SE Version 9
Could someone please provide me with the correct formula?
Also a solution to the equation with the parameters listed?
Thanks so much!
Hello, I have problem i'm working on boiler plc, but i get to the problem that i can't solve myself. I have problem with material gate. I need to...
351
HI All : We have a boiler that can produce up to 75000 lb/hour, this boiler has two CompactLogix Plcs from Allen Bradley , one is used for burner...
3,898
hi everyone im using OPERATOR PANEL SPOT PLUS 150 35W 24VDC AUTOMATA ID42003 (as hmi system) and automata optispark controller to control and...
2,411
Good day Gents, Does atmospheric pressure have an influence of a boiler steam pressure.
31
8,595
Looking for a programmer with Opto22 and fluidized bed boiler experience or just Fluidized Bed Boiler Experience. Company or individual
1,577
