plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old January 11th, 2005, 02:37 AM   #1
Scooter
United States
Scooter is offline
Scooter's Avatar
RSLogix500 vs ICOM Software
We have a pallet strech wrapper that has a Allen Bradley SLC 500 fixed PLC 1747-L40A, It was programmed years ago with ICOM Software.
Everything is fine but I want to download the program and install a eeprom as it only has the battery back-up.
We have RSlogix500, RSLinx and the PIC converter.
I have been afraid to even attempt to communicate with this because the software may not be compatable.
Question is: Can I extract the program using the RSLogix500 or is there going to be a problem being it was programmed with the ICOM software.
I do have a print-out of the program and it looks like standard RSLogix500 format, I could manually convert it to RSLogix.
Thanks....
Old January 11th, 2005, 03:57 AM   #2
PhilipW
New Zealand
PhilipW is offline
PhilipW's Avatar
Location: Wellington, New Zealand. Islands on the edge of the world.
Go ahead. The SLC does not care at all whether ICOM or RSLogix500 is attached to it. It will be 100% compatible.
Old January 11th, 2005, 12:13 PM   #3
Scooter
United States
Scooter is offline
Scooter's Avatar
Great, Thank-You!!!!
Old January 11th, 2005, 12:44 PM   #4
Ken Roach
United States
Ken Roach is offline
Ken Roach's Avatar
Let's make that 99.8% compatible.
There were some ladder constructs that the original ICOM software and the old A-B "APS" software would allow that RSLogix 500 considers illegal. Some very old controllers will get a "decompiler error" when trying to upload an old program with RSLogix 500.
There's no danger; the program stays in the controller and isn't damaged.
There's a fairly easy workaround; there is an AI-500 based upload utility that Technical Support can give you to upload the program. From there it will convert easily to RSLogix 500.
Go ahead and try to upload your program. Odds are extrememly good it will work without a hitch.
Old January 11th, 2005, 03:49 PM   #5
93lt1
United States
93lt1 is offline
93lt1's Avatar
Re: Let's make that 99.8% compatible.
Just out of curiousity...
What could you do in A.I. or APS that is considered illegal in RSLogix??
Old January 12th, 2005, 02:09 AM   #6
Scooter
United States
Scooter is offline
Scooter's Avatar
Thanks Ken, I have A/B APS programming software loaded on an old desktop pc sitti'n in the corner of the shop, It still works.
The APS software is DOS and now I am wondering if ICOM is DOS also?
This unit I am working with was OEM programmed in 1995.
Old January 12th, 2005, 07:55 AM   #7
93lt1
United States
93lt1 is offline
93lt1's Avatar
Quote:
ICOM is another name for A.I. It also runs on DOS. Most people claim they like(ed) AI or ICOM better than A.P.S.
Old January 12th, 2005, 04:44 PM   #8
Fred Floggle
Ajman
Fred Floggle is offline
Strange what you get used to ............ A hundred years ago i used to program a lot of quite fast sequencial control machines using Omron c20hs processors , and the highlight of my life was getting SSS software , why ? not because of anything more than it didn't require the use of horrible canister files . i still reckon I can program faster with the old dos based tush than with the windows stuff i tried - not only that , i thought about , and understood what i was doing . you will remember no TOF , you made it , takes a couple of lines of logic ? many people think that's wrong , one rung is enough , let's see who can get it right . ps , if you do know , don't tell.
I have used the APS to AB import utility many times with few probs , upload it with aps to be sure , and try a convert .
Old January 13th, 2005, 02:28 AM   #9
Scooter
United States
Scooter is offline
Scooter's Avatar
Ok, Now I have to ask: What came first? ICOM, A.I. or APS.
Were all these programs produced by Allen Bradley?
Or was there a second party involved.
I used the APS Software for one project 10 years ago
and never needed it afterwards.
I did not try to "upload" the program yet, The machine is in use.
Old January 13th, 2005, 02:44 AM   #10
Fred Floggle
Ajman
There is quite a story regarding the software - I recall that there was a company called Greysoft who developed the original software (ladder90) for the siemens brick processors and prevented others from using their GUI (or something like that )
You should be OK going for a quick upload - though don't blame me if your factory gets filled up with peas and Captain Birdseye gets cross.
Old January 13th, 2005, 03:45 AM   #11
Doug_P
United States
Doug_P is offline
I believe A-B's APS was first.
ICOM - a separate business entity - produced the A.I. (Advanced Interface) series software for A-B processors. There were also versions for PLC-2 and PLC-3.
Old January 13th, 2005, 08:03 AM   #12
93lt1
United States
93lt1 is offline
93lt1's Avatar
Quote:
And PLC-5.
I still have a vintage ICOM catalog from 1994. Also available is WINtelligent VIEW, WINlogic 5, and WINtelligent Linx.
Rockwell bought ICOM and basically re-named the operation "Rockwell Software"
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
RSI developing software BobB LIVE PLC Questions And Answers 16 May 21st, 2010 02:52 PM
rslinx and Excel with AI Icom software mulderm LIVE PLC Questions And Answers 4 January 19th, 2005 12:36 PM
rslogix500 w/sp2 jimpad LIVE PLC Questions And Answers 7 December 19th, 2004 07:48 PM
Need help on EV Move utility for activation key using ICOM version 6.19 for PLC2. John Salazar LIVE PLC Questions And Answers 11 April 15th, 2004 02:58 PM
Install ai series (icom) with Rslogix5 mulderm LIVE PLC Questions And Answers 1 June 18th, 2003 10:13 AM
