PV600 to PLC5 Node name issue
booten
Jun 2004
Kansas
45
Does anyone know what the squiggly line in this processor name means and how to address it in the PB32 application?
Thanks Bill
There are 3 other PLC 5's and one PV1200 on the network I am just trying to add this PV600 to it.
Just tried to add a ~ to the name of a PLC5 processor. Would not accept it.
Have a look in the other panelviews for the node name of the PLC.
Regards Alan
have seen this squiggly line in dos based systems when filename is longer than 8 characters. i.e. mycomputer.doc becomes mycomp~1.doc
hope this helps
Allan Case,
I was incorrect about the PV1200, it is on RIO.
bellies,
That is probably what happened.
This PLC application was imported over to RSLogix from AI series. I looked back at the old AI series files (still have them saved) and I see that they also have that line. The PLC5 must be made to accept it some how from the import utility.
jstolaruk,
I will try going without the line and see what happens.
Thanks everyone,
Bill
I'm a beginner to PLC and Hmi programming. any one please help how to connect HMI to pc. HMI has a printer **** enabled by default, It does not...
432
Hello, I've recently tried to upgrade my PLC controller from a L72 to L84ES and everything seemed to work, all buttons and screens as far...
2,651
I imported the pva into Factory Talk View Studio and it gave me some errors. Alarm message Ack option not supported. Blinking color images are...
1,795
I'm trying to set the date and time on a Panelview 600 plus 2711P-T6M20D8 SER A. I looked for a white square to pop up in the lower left...
1,806
Hello forum, Simple question from a newbie. We have a PV600 showing all nodes in error. The Link coupler power LED is not illuminated and a...
2,027
