Convert slc logistics file (ICOM) to SLC500 (.RSS) ?
katratzi
Mar 2005
210
Can someone tell me if it is possible to convert a file
that was developed using the SLC Logistics software by ICOM to an (*.RSS) file that can be read by RSLogix500? Will Logix500 open this file as is?
rdrast-
There are eight files associated with the project. Their extensions are: .dfg (70kb), .slc(3kb), .sld(27kb), .slf(1kb), .slp(8kb), .slr(26kb), .slt(1kb), and .slx(8kb). I do not know which one contains the ladder.
I believe the .slc is an ascii export format and rslogix500 should be able to open it. The ICOM/AI would have a .ACH extention as one of it's primary file type.
You are right. I'm sorry, I didn't mention that these files were
from a SLC-150 plc. Duh. I think I was just hoping there was a way to convert this so it could be opened in RSLogix500.
No, it can't be converted to Logix500... The addressing and instructions are different. To open that, you need PCIN from AB, I don't have a copy here, but might have one at home. I'll look around if needed.
I'm trying to convert an RS Logix 500 fille when I open the 500 file and try to "save as" a .slc file, it does not allow it. It says " SLC library...
694
Hello everybody, Could you please confirm if there is any automatic or semi-automatic tool to convert projects: 1. Convert a PLC5 project (.RSP)...
1,606
Hello everyone, I am migrating a program from STL to SCL via S7-1200 portal, I would like you to help me by converting these lines of code...
1,635
We have 3 SLC-150s that we are using, we would like to create a print for them and diagram the program so when we get approval we can replace them...
2,650
Any body willing to convert a program from a SLC 5/05 to a pdf for me? Please PM me. Thanks!
1,672
