To convert .rsp file to .slc and Convert .acd to .slc
Aug 2022
Quito
Hello everybody,
Could you please confirm if there is any automatic or semi-automatic tool to convert projects:
1. Convert a PLC5 project (.RSP) to a project (.SLC)
2. Convert a Logix project (.ACD) to a project (.SLC)
For your support and help, thank you very much.
Welcome to the forum.
I do not know of any conversion tool to go backwards.
you can go from slc and plc5 to logix.
the only way it might work is to copy and paste.
if i am incorrect, someone please correct me.
james
james
Copy & Paste is the only way I know except for a couple of issues.
CLX tags won't paste into RSLogix 5 or 500.
CLX has instructions not supported by SLC.
PLC5 data files have higher numbers possible than SLC's (IE - B3:1024/15 vs B3:255/15 limit)
I was hoping that someone would be able to help me convert this PLC5 file to something that I can open with Logix500. Please help if you can. Thanx
27
10,833
Hello, could someone kindly convert the attached RSP files that are currently used for SLC 5 PLC into PDF please
534
I currently need to download about 400,000 bits of RSLogix 5 from four Allen Bradley SLC 500 to a flash stick for printing or viewing. Does anyone...
3,969
We recently purchased a machine with a PLC5 controller, never used this before, we are all SLC. Can someone convert this AB program to pdf for...
2,257
Hello all, I'm currently working on a servo motor linear positioning system (ball screw). I'm all set up regarding communication between my HMI...
92
