plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old May 27th, 2003, 03:20 AM   #1
C Henk
Belgium
C Henk is offline
C Henk's Avatar
MicroWin32 opening an old project
Hello,
Can somebody explane how I can open an old MicroWin project.
When opening a project, you can choose for a file with the extension prj.
When I trie that, microwin gives me an opening error.
I must open it with an earlier version and than do some stuff and savening it...but I don't have an earlier version...
Can somebody help me
Thanx
Old May 27th, 2003, 06:14 AM   #2
boyo
Wales
boyo is offline
This problem usually occurs when the program is written in LAD and the newer compiler has some problem with a LAD element from a previous version. If you can get hold of an earlier version then Open the project file, view it in STL and then save it with a different name to preserve the original. Then you should be able to open the STL file with the new Microwin and convert it to LAD.
Check the Siemens website for demo versions of Microwin. You might get lucky otherwise I can't think of another way to do it.
Boyo
Old May 27th, 2003, 03:16 PM   #3
jvdcande
Belgium
jvdcande is offline
jvdcande's Avatar
In MicroWin the prj file is the file which points to all other files.
To import an old S7-200 program, you best start a new project and subsequently import the old Micro/DOS project by using the menu "Project - Import - Micro/DOS project".
If this doent work you can subsequently try to enter all the parts of the old Micro/DOS project separately:[list=1][*]the program itself - Project - Import - Program Code Block - *.ob1 or *.awl[*]the datablock - "Project - Import - Data Block" - *.db1[*]the symbol table - "Project - Import - Symbol Table" - *.sym[*]the status chart - "Project - Import - Status Chart" - *.cht[/list=1]
Hope this helps,
__________________
Jean Pierre Vandecandelaere
Trainer nautical sector
VDAB Competentiecentrum
L. Blondeellaan 9
B-8380 Zeebrugge
Belgium
Old May 28th, 2003, 02:43 AM   #4
boyo
Wales
boyo is offline
Hi JP,
You're right of course that sometimes only one element e.g Data Block can be corrupted and this will prevent the whole project from opening.
Having said that I still think the best bet is to try and obtain a slightly older version and try opening the project with that. Even if he doesn't want to work with the older version(who does?) then it will enable him to save it as STL, or export as AWL.
Best regards
Boyo
Old May 30th, 2003, 10:02 PM   #5
RRobbins
United States
RRobbins is offline
RRobbins's Avatar
Jean Pierre is right. The .prj file was an old MicroDOS project file. You need the entire group of files and look under the file types in the "OPEN" file box while in MicroWIN.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Can't open project (STEP 7) Greet LIVE PLC Questions And Answers 7 February 7th, 2005 01:46 PM
RSLogix 500, move project between laptops jdbrandt LIVE PLC Questions And Answers 0 November 30th, 2004 09:48 AM
Funny effects when uploading project to S7 300 CPU RMA LIVE PLC Questions And Answers 9 October 28th, 2004 07:44 AM
How much is a Step 7 project worth in €? NoName LIVE PLC Questions And Answers 7 May 14th, 2004 08:41 AM
Senior Design Project Suggestions...... Justin Lane LIVE PLC Questions And Answers 10 September 19th, 2003 11:03 AM
