Hyper Terminal replacement and other tools
JOLTRON
Aug 2006
MI
692
I am looking for a replacement for hyperterminal. My XP system doesn't have hyperterminal or telnet. I am currently trying to use PuTTY but it isn't as user friendly due to the complexity of everything you can do. So I am wondering what the pro's use out there.
Also I have found a Fox-toolkit calculator that figures out bit shifts left and right. I was wondering if any one knows of another bit shift calculator or any other nifty tools.
You're sure you don't have HT? It was bundled natively up through XP (Not in Vista, I think.) If it's not there, you should be able to find an XP install disk and add it.
In my XP it's Start > Accessories > Communications > Hypterterminal
I use Realterm as well.
I lost my trust of Hyperterminal when I caught it deleting bytes when three identical bytes came in sequence. Bad terminal program. Bad !
Yep, I'm sure. I have looked thru multiple times. It was on previously then IT worked on my laptop formated and re-installed xp and now it no longer exists.
You could get your IT to add hyperterminal via the add/remove windows components in the control panel
Thought about that but things are alot easier not dealing with them. Plus they are contract and only onsite once a week. Also I heard that hyper terminal isn't even in vista. So if i ever changed OS it nice to know the name of other options. So far I have tried all 4 of these programs listed.
PuTTY
Real Term
LKA
Tera Term
And for what I have done I like Real Term the most options but still pretty simple, next choise would be Tera Term for it's simplicity.
I user a simpler utility- visual protocol simulator
download from this link
http://www.microsant.com/download.html
Trying to test a Channel 0 ASCII to Hyper Terminal using 1747-L532 Channel 0 is set to user Do I use a Straight through cable or Null Modem from...
1,582
I have an external device which will move the specified test data to the COM port. Can you please give me the source code which will move the data...
4,426
Just curious if anyone has any recommended solutions for gaining my USB-A to miniUSB adapter inside my VM Having an adventure with an M3401000...
1,147
Hello friends The IT department is pushing me to use Hyper-V on Windows 10. Have you use it? Is it a good option? Thanks in advance.
4,291
Anyone ever set up Archestra in a Hyper V configuration in windows 2008 R2 Need some help Thanks
1,469
