plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old April 15th, 2009, 06:30 AM   #1
Rheinhardt
South Africa
Rheinhardt is offline
Melsec Medoc 2.5
Help guys,
Mitsubishi ...well enough said. After chasing my tail between GX Developer,IEC GX Developer i have found out i have software that was written in Melsec Medoc 2.5.
Are these versions still available???? I used a MS-Dos version years ago cant even remember the version. All the forums i'm reading on this is dating back to 2001...
Does anyone know of any updates on this package that i can use.. Maybe Melsec Medoc Plus??
__________________
Rheinhardt Peens
Old April 15th, 2009, 07:28 AM   #2
tragically1969
United Kingdom
tragically1969 is offline
Quote:
Originally Posted by Rheinhardt View Post
Help guys,
GX Developer will import Medoc programs, i cant remember how to do it as i havent used Mitsi for a few years now, i am sure somebody will be along in a minute that can tell you..........
Old April 15th, 2009, 08:01 AM   #3
Andybr
United Kingdom
Andybr is offline
To import a Medoc programe into GX Developer you must first create a new project with the correct PLC type. Once you have a project the options to import will be available in the file menu. Most programmes can be imported straight from the Medoc file but this will sometimes fail, especially if there is a very large name list. If this happens then you need to generate a Medoc print file (but, of course, you need Medoc to do this). The print files can usually be imported even if the actual programme file cannot.
Andybr
Old April 15th, 2009, 08:12 AM   #4
jrwb4gbm
United States
jrwb4gbm is offline
I dont know anything about this software but I found this:
http://www.meau.com/functions/dms/ge...00001580900000
and this link:
http://www.control.isy.liu.se/studen.../reference.pdf
Hope this helps.
Old April 15th, 2009, 09:12 AM   #5
Rheinhardt
South Africa
Thank you
I have actually tried doing the import, with no success, what is the proper file extension for Medoc program? It cannot even see the files.. Some users on the forum and our local distributor says the software was done in the IEC version of GX Developer,
http://www.plctalk.net/qanda/showthr...ght=mitsubishi
but the company that did the project +- 2 years ago say Melsec Medoc 2.5. which is not available locally.
I will specify the file types again.
custom.sys okb
edm.edm 2kb
lryboxes.sys 1kb
softctrl.pro 3,360kb
Would i be able to upload the project into GX Developer if the program was done Medoc 2.5? What would the result be in terms of configuration, comments,symbol lists?
At the point of No return!!!
Thanks again
__________________
Rheinhardt Peens
Old April 15th, 2009, 09:16 AM   #6
Andybr
United Kingdom
Andybr is offline
The files you have listed are definitely not Medoc files. The IEC version of GX Developer was originally marketed as Medoc Plus and this could be where the confusion is coming from.
Old April 15th, 2009, 09:24 AM   #7
Rheinhardt
South Africa
http://www.plctalk.net/qanda/showthread.php?t=9808
Additional info.
Anyone know the file extensions for GX-Developer IEC.
__________________
Rheinhardt Peens
Old April 15th, 2009, 09:34 AM   #8
tragically1969
United Kingdom
Additional info.
GX IEC File Info:
http://www.plctalk.net/qanda/showthread.php?t=37476
I seem to recall that Beijers had a hand in the Medoc name, perhaps it is this version that the program was written in, in that case you will need to do some more digging.
Old April 15th, 2009, 10:12 AM   #9
Rheinhardt
South Africa
Thank you for all your help and assistance!! I will download the IEC GX Developer Demo and hopefully get some succes..
I will get back to the forum after i have done this.
__________________
Rheinhardt Peens
Old April 15th, 2009, 10:24 AM   #10
tragically1969
United Kingdom
But it isnt a GX IEC program !!
Old April 16th, 2009, 08:57 AM   #11
Rheinhardt
South Africa
Talking
Tragically,
You were correct, i managed to fins a Melsec Medo 2.5 version and it works fine.
Thanks for all the help guys!!!
__________________
Rheinhardt Peens
Old April 16th, 2009, 01:28 PM   #12
504bloke
England
504bloke is offline
504bloke's Avatar
Help guys,
I have an FX2 in my office used as a door stop, always makes me smile
__________________
Regards
Dave
"When you are courting a nice girl an hour seems like a second. When you sit on a red-hot cinder a second seems like an hour. That's relativity."
Albert Einstein (1879-1955)
Old April 17th, 2009, 07:34 AM   #13
Rheinhardt
South Africa
This one almost went the same way...glad we got it going though.... Just to many software packages for the mitsubishi hardware... makes it a nightmare.
__________________
Rheinhardt Peens
Old April 17th, 2009, 01:55 PM   #14
Sergei Troizky
Canada
Sergei Troizky is offline
Tragically,
Can you share the source?
Old August 24th, 2017, 04:54 PM   #15
Max4507
Canada
Max4507 is offline
Hi all!
I know I am bringing an old post back.. but I need to open an old Mitsubishi FX1N program which I think was programmed with Medoc!
Anyone still have the program?
Or even better, if someone is able to open my program backup, convert it, and send it back in a GX Developer version.. would be really appreciated.
Best regards,
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Melsec Medoc Software cradle LIVE PLC Questions And Answers 13 June 15th, 2013 10:55 AM
Melsec Medoc. I know it's old, but... tony.del LIVE PLC Questions And Answers 3 September 21st, 2007 09:06 AM
Melsec Medoc installation problems zalmaflash LIVE PLC Questions And Answers 6 February 5th, 2007 11:45 AM
Where Can I get MELSEC MEDOC ?? markbray LIVE PLC Questions And Answers 3 November 5th, 2004 05:58 PM
Having problems printing in Melsec Medoc 1.6 Larssa_ LIVE PLC Questions And Answers 1 October 2nd, 2003 11:58 AM
