plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old April 20th, 2009, 11:48 AM   #1
titi_nicolas
Switzerland
titi_nicolas is offline
Beckhoff - twincat problem (newbie)
I am trying to program a PLC code on a CX9000 with TwinCat.
I spent the last days configuring the hardware and I think it is fine. I found some interesting tutorials on Youtube on how to connect and configure a CX device and I strictly followed them.
What is working so far:
- I can ping the CX.
- From the System Manager, I can connect to the CX and find the plugged terminals.
- I can map my variables to the physical terminals.
- The status bar in the System Manager says "Config mode" or "Run %" (i.e. no "Timeout" that would means that there is a connection problem).
Nevertheless, when I try to Login to the CX from TwinCat, I get an error message "Wrong PLC type connected". But the status bar at the bottom of the panel says "TwinCat Running" and the target field displays the correct device.
Moreover, I can also get an other error message "TwinCat run-time already running" if I try to login.
I could not find any help in the manual or the web regarding those error messages.
Does anybody can help me?
Thank you very much.
Old April 20th, 2009, 04:33 PM   #2
Jon R
United Kingdom
Jon R is offline
Jon R's Avatar
Have you configured the AMS router to your CXs IP address?
Are you creating your program in PLC Control using the correct project type?
When you try to login through PLC Control, after you have your AMS configured and you are using the correct project type, you will need to select the runtime system you wish to use. If your AMS is setp up correctly you should see the local system(your local PC) and your CX device. Select the CX device and expand to show the port connection( not sure what it is for CX but for BC it is 800) and you should be able to login.
Jon.
Old April 21st, 2009, 03:02 AM   #3
titi_nicolas
Switzerland
Hi Jon,
I left the AMS address unchanged to its default value. I read that for the "embeded PC" devices the AMS and IP can be different. Nevertheless, to make sure I gave a try which does not solve the problem.
I have already done what you suggested:
- start a new project with "target system type" = "PC or CX(x86)".
- select the "run-time system" = "run-time 1 (port 801)" of the CX device. (see screen shot)
- login... error "wrong PLC type".
Other ideas?
Old April 21st, 2009, 06:43 AM   #4
LadderLogic
United States
LadderLogic is offline
LadderLogic's Avatar
Try changing project type to "CX (ARM)". I am not sure but CX9000 may be different from other CX's.
__________________
Don't trust, don't fear, don't beg...
Old April 21st, 2009, 07:39 AM   #5
titi_nicolas
Switzerland
it is working indeed!
I was pretty sure I tried the "CX(arm)" option before...
I was also sure my CX had a x86 processor!!!
Many thanks!
Old April 21st, 2009, 01:23 PM   #6
LadderLogic
United States
Talk about messy approach... CX1010 and up are x86, but CX9000 is ARM. Why such a confusing model numbering system - is beyond my comprehension...
__________________
Old April 21st, 2009, 10:15 PM   #7
Archie
United States
Archie is offline
Just an FYI for anyone else needing help getting connected, this is the video on YouTube that was referred to:
http://www.youtube.com/watch?v=8T171NIyH74
__________________
Expectations lead to disappointment. Appreciation leads to satisfaction.
AdvancedHMI - HMI Software without the license key hassles
Old September 19th, 2009, 03:12 PM   #8
FilipN
Belgium
FilipN is offline
i have the same problem but with the local runtime simulator
Old January 9th, 2011, 01:47 PM   #9
eng.abbas
Iraq
eng.abbas is offline
When you start the mixer central words appear on the screen of BX9000 (DEFAULT-CONFIG) How can I treat this case and I hope you to send me the file settings for this sweet concrete mixer?
Old January 14th, 2011, 11:02 AM   #10
conelson
United States
conelson is offline
Quote:
That means there is no program loaded.
Old January 28th, 2015, 09:44 AM   #11
Ing.S.Agius
Malta
Ing.S.Agius is offline
TwinCAT error when switched to Run Mode.
I am new to TwinCat 3 and to PLC programming.
I made a program on TwinCat 3 to experiment a little bit. When I switched to Run Mode TwinCat gave me the following error:
Error 15 27/01/2015 23:23:48 551 ms | 'TwinCAT System' (10000): Sending ams command >> Init4\RTime: Start Interrupt: Ticker started >> AdsWarning: 4115 (0x1013, RTIME: system clock setup fails.
Hint: On Windows8 system execute win8settick.bat in TwinCAT\3.1\System as administrator and reboot.) << failed!
I am running TwinCat 3.1, Engineering eddition on Windows 8.1 64-bit operating systems.
Any suggestion of how I can solve this error is more than welcome.
Thanks alot
Old February 4th, 2015, 10:10 AM   #12
RocketTester
United States
RocketTester is offline
Ing.S.Agius,
Do you have Beckhoff hardware? If so, what processor? If you have hardware, you must first set a route to it from your Visual Studio PC, then choose it in the System folder (used to be stand-alone System Manager). Once selected, you will see the AMS ID in the lower right. On a new system, one normally finds the I/O, clicks "Activate Configuration", then it prompts you to switch to Run mode.
I don't know about "simulation mode", if that is what you are trying to do. If so, try to follow the Hint they gave you. It might also be a Win8-specific thing, if you are running that (I haven't).
Old October 11th, 2017, 02:49 AM   #13
thiseful
Romania
thiseful is offline
thiseful's Avatar
Hello
I hope I will find somebody to answer me since this thread is quite old.
I have TwinCat 3.1 installed on a win10 64 bit laptop.
My target PLC is a Beckhoff CX2020.
I am conected to the PLC but when I try to login an error appears :"TwinCat PLC Control System not Connected"
Any ideas?
Old October 11th, 2017, 07:46 AM   #14
Fredrik_swe
Sweden
Fredrik_swe is offline
In bios, turn off SecureBoot and turn on CSM.
Old October 11th, 2017, 08:07 AM   #15
thiseful
Romania
thiseful is offline
thiseful's Avatar
Quote:
I had done this awhile back still have the same issue
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Honeywell PLC 620-1633 bootup problem. ramrap.r LIVE PLC Questions And Answers 1 December 6th, 2011 03:42 AM
Beckhoff twincat SMTP supplement Pete:-) LIVE PLC Questions And Answers 5 December 12th, 2008 09:29 AM
OT: Headscratcher problem with servo hydraulic cylinder. TConnolly LIVE PLC Questions And Answers 12 October 9th, 2008 08:59 PM
Ab Plc5 Rio Problem. fernandes LIVE PLC Questions And Answers 5 March 7th, 2004 02:25 PM
PLC5/40 Backplane Problem????? Andrew Evenson LIVE PLC Questions And Answers 18 August 24th, 2002 08:06 PM
