just_lionel
Hi All,
We have a Telemecanique Altivar 61 that is attached to a pump motor that pumps water out of a creek to a center pivot. So far so good!
The old setup used a old pressure transmitter that when a certain pressure was hit (by selecting by hand) the contacts would open and drop out the contactor. This system is no longer there at all. I have a Barksdale 425N1-06 (0-200 PSIG) pressure transmitter that we are using. The way this system is set up from what I can tell is as long as there is pressure, the system will run, if it goes too low or too high (pressure of 0 or over 200) the drive stops.
My question is this; there are four different center pivots we use. They range in what pressures they can take, 125PSIG, 150PSIG, 175PSIG, 200PSIG. What would be the easiest way to setup the drive to be adjustable to the signal coming back from the pressure transmitter?
The guy who will be running this needs it simple, don't need him into the drive parameters. I was wondering could I hook up a potentiometer to the drive and allos adjustments that way or be able to program 4 different setups with a selector switch.
BTW: The drive is setup for PID tuning so it adjusts drive speed as need to maintain constant pressure.
