plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old July 31st, 2009, 03:14 PM   #1
drawson
Canada
drawson is offline
RSLogix 5000 - AOI - Rounding
I am trying to create an add-on instruction to round a value.
I have defined the following parameters for the instruction
INPUT: ValueToRound --> REAL
INPUT: Places --> DINT
OUTPUT: RoundedValue --> REAL
I've written the code as follows
IntermediateValue1 = ValueToRound*(10^Places)
DecimalPortion = IntermediateValue1 - TRUNC(IntermediateValue1)
If DecimalPortion >= 0.5 Then
RoundedValue = TRUNC(IntermediateValue1+1)/(10^Places)
Else
RoundedValue = TRUNC(IntermediateValue1)/(10^Places)
End_If
My problem is as follows: If I enter
ValueToRound = 3676.4444
Places = -2
The function calculates the values as 3699.9998 not 3700 as I expected. I assume it has something to do with the floating point math but can't figure out why. Dividing a truncated value by a power of 10 should work.
Any Suggestions?
Old July 31st, 2009, 04:22 PM   #2
TConnolly
United States
TConnolly is offline
TConnolly's Avatar
First off, I have to ask, why are you rounding? Except for display purposes, there is seldom an good reason to round IEEE-754 floats, and the operations to do it are rather complex.
I apologize if this seems a bit pedantic, I'm just trying to explain what the challenges are in what you are trying to do.
There are many numbers that cannot be exactly represented in the IEEE-754 floating point format. 36.764444 happens to be one of those. So right out of the chute, you encounter a problem. This one however doesn't have a say in the outcome, as all you are doing is looking to see is if .764444 is greater than or less than .5.
It is greater than so it seems intuitive that if you add one to 36, giving you 37, you are good do go. But in order to get there, you want to multiply and divide by 10^-2, and here is where you hit a brick wall. 0.01 is another number that cannot be represented in an IEEE float. Instead, .01 becomes .0099999998. Look at the result you actually got and its pretty obvious where this is going. I have even more bad news. Not only is .01 not exactly representable, but .1, .001, .0001, .00001, .... .000000000000000000001, etc are all numbers that cannot be exactly expressed in IEEE-754 float format. And those happen to be the very numbers expressed as 10^-n.
Now modern programs have complex algorithms that round values for display as a string of characters on your computer screen, so you see .01 on your screen, but that is a string, not a number. Inside, in memory it is .0099999998, and when you perform a computation that is what is used.
So, what to do about it?
What is the range of numbers that you will be using? Is the conceivable range of numbers, after shifting the decimal place, within the range of a DINT?
I suspect that they are - besides, long before you exceed the range of a DINT your float will start to suffer from resolution problems that render rounding to two or three decimal places moot, but that is another topic altogether. So if the answer is yes, then I suggest you multiply or divide depending on the sign of n by 10^|n| where 10^|n| is a positive integer, not a float, and make the destination address a DINT. This will automatically round. Then divide or multiply by 10^|n| again depending on the sign of n to an integer destination, then move that to your float.
In your example, start with
CPT XTAG (10**ABS(Places))
XTAG is type DINT
Use XIC Places.31 and XIO Places.32 to see if Places is negative or positive.
because bit Places.31 is set, Places is negative, so divide.
DIV 3676.4444 XTAG DINT_TAG will put 37 in DINT_TAG rounding automatically (well not actually automatically, the processor will jump through all kinds of complex gymnastics to make the conversion, but it will do it for you instead of you coding it.)
Now MUL DINT_TAG XTAG DINT_TAG will put 3700 in DINT_TAG.
Finally, MOV DINT_TAG REAL_TAG
For cases where N is positive, do the opposite, multiply first, then divide.
Over at MRPlc.com in the downloads section http://forums.mrplc.com/index.php?au...s&showfile=761 I have posted a program written for the PLC/5 and SLC500 platforms that does tuncation and rounding by direct manipulation of the IEEE-754 float's mantissa. You can take a look at it and see what's involved behind the scenes, but even it won't work for all possible numbers.
Is places always going to be negative? If so then there are some other easy solutions.
Last of all, I have to ask again, why are you rounding? I'm just asking because we have seen other posts here where someone was attempting to round a number and it really wasn't necessary and boiled down to a misunderstanding of what the number meant and how it was really represented in the processor.
__________________
True craftsmanship is only one more power tool away.
That's the beauty of processors, they don't have emotions they just run code - The PLC Kid.
Old August 5th, 2009, 08:40 AM   #3
drawson
Canada
drawson is offline
Alaric thanks for the info.
I am rounding because I am required to do so by specificiation. We produce API well casing and are bound by the specification created by API. They define the hydrostatic test pressure using a calculation based on pipe diameter, wall thickness, and specified minimum yield strength. The result of the calculation is then to be rounded to the nearest 100 psi and used as the test pressure for that particular product.
I decided that while I was creating a rounding routine I had might as well create and AOI that I could reuse rather than just one-time code for this project. I took your advice and used DINT data types instead. Thanks for the help.
I have never fully understood floating point data before. I always thought of it simply as a structure to hold a real number.
Thanks Again.
Old August 5th, 2009, 09:12 AM   #4
TConnolly
United States
TConnolly's Avatar
I'm glad I was able to help.
Here is more info on how floats are stored:http://en.wikipedia.org/wiki/IEEE_754-1985
If you want to see what a particular float looks like in Binary, here is a useful tool:
http://babbage.cs.qc.edu/IEEE-754/Decimal.html
I need to make a correction to my post above. I wrote
Apparently I fat-fingered the keyboard. It should read:
Use XIC Places.31 and XIO Places.31 to see if Places is negative or positive.
For those who may read this in the future but who don't understand what its doing, bit 31 of any dint is the sign bit. If it is set the number is negative, if it is clear the number is positive.
__________________
Old July 18th, 2017, 09:46 AM   #5
votecoffee
United States
votecoffee is offline
Round using MOV
Using MOV to copt the value from a real to a dint is a simple way to round that accomplishes roughly what you want. .5 cases are a little odd in that they round to the nearest even number due to the nature of floating point numbers not being able to represent .5 exactly.
See http://www.plctalk.net/qanda/showthread.php?t=95690 for a good writeup.
Old July 18th, 2017, 02:02 PM   #6
hoy7t
United States
hoy7t is offline
Here is the simple rounding algorithm:
RoundedResult = truncate(RawData + 0.5, 1) for 1 digit precision
RoundedResult = truncate(RawData + 0.05, 2) for 2 digit precision
Old July 18th, 2017, 02:30 PM   #7
votecoffee
United States
Sorry, missed the requirement for varying precision. Likewise, for large numbers (ABS > 2 billion) this wouldn't be useful.
Old July 18th, 2017, 02:41 PM   #8
JordanCClark
United States
JordanCClark is offline
JordanCClark's Avatar
Not sure why we're posting to an eight-year-old thread...
__________________
_____________________________
Jordan
Any man that can hitch the length and breadth of the Galaxy, rough it, slum it, struggle against terrible odds, win through and still know where his towel is, is clearly a man to be reckoned with.
-- Hitchhiker's Guide to the Galaxy
Old July 18th, 2017, 02:44 PM   #9
LoganB
United States
LoganB is offline
damn, I was just about to post a necro gif too lol
__________________
Present: Controls Engineer
Future: Skynet Engineer
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
AOI in rslogix 5000 finibx LIVE PLC Questions And Answers 3 July 6th, 2009 01:27 AM
Day of week AOI error in RSLogix 5000 rta53 LIVE PLC Questions And Answers 0 January 9th, 2009 03:17 PM
RSLogix 5000 Add On Instruction (AOI) to HMI NFischer1978 LIVE PLC Questions And Answers 0 September 19th, 2008 06:13 PM
Gray Code and RSLogix 5000 IAA LIVE PLC Questions And Answers 5 September 28th, 2007 09:27 AM
RSLogix 5000 V15 Features Samneggs LIVE PLC Questions And Answers 18 April 20th, 2006 05:45 PM
