can´t complete integration of the WinCC flexible project on step7
gtoka
Sep 2010
Bs.As
20
hey guys,
im trying to integrate the project following this tutorial:
Proceed as follows to integrate a WinCC flexible project in STEP 7.
1.Open the WinCC flexible configuration.
2.Select the menu command "Project > Integrate in STEP 7...".
The "Integrate in STEP 7 projects" dialog opens.
3.Select the relevant STEP 7 project in the dialog box.
If the project you desire is not listed, navigate via the search field to the folder in which the STEP 7 project is located.
Integration is executed once you select the STEP 7 project.
This 3 steps is ok!
Now:
Parameterization of the connection / communication partner
In the "Stand alone" mode you have set all the connection parameters to the controller manually.
In the "Integration" mode you can define the station via which the communication partner is to be addressed using the selection menu. The addresses are then transferred automatically.
Furthermore, using this measure with the tags, you can access the symbolic connection.
4.Open the STEP 7 project in which you previously integrated the WinCC flexible project. OK
5.Mark the HMI station and double-click to open the "Configuration" of the HMI station.OK
6.Open the "Properties" of the operator panel's interface and define the interface and address.????????????????????
in my configuration does not appears this!
please any help?
thanks
Hi, I am new to this forum. I am trying to get into the program offline of one PLC Fanuc GE 90-30. To see the program I downloaded the software...
548
Hello to All, Recently I install a CP343-1 Lean to communicate with a CPU 314 IFM, however I can't go online when I'm connected via CP343-1 Lean...
1,681
Hi Guys. i have a one production line where is the processor is CompatcLogix L35e, and 2 DeviceNet Scanners. Today our electricians told me a...
1,656
Hi everybody. I´am a little new programing HMI. I know that is important make an alarm and event historian database, which will save the alarms of...
3,991
Hello, Who knows where the hidden files evrsi.sys and 386swap.par are on the harddisk from Windows XP? I can not find these. I use RSLogix5...
9,603
