Can´t go online on a CPU 314 IFM via CP 343-1 Lean
bval
Sep 2021
Lisbon
Hello to All,
Recently I install a CP343-1 Lean to communicate with a CPU 314 IFM, however I can't go online when I'm connected via CP343-1 Lean (using ethernet cable).
When I use MPI interface I can go online and see all modules settings.
Any Help?
Ps. I have other machine with the same hardware and I can go online via CP343-1 Lean, I already compared all settings but something is missing!
Thank You
Bruno Valente
Exactly the same hardware in the working and non-working systems ?
An IFM CPU is very old. I know that there are some incompatibilities with the CP343-1 LEAN and very old CPUs.
Have you downloaded an uptodate HW configuration to the S7 CPU ?
According to the CP343-1 LEAN manual, the 314-IFM CPU is supported as of 6ES7314-5AE03-0AB0
6ES7314-5AE00-0AB0, 6ES7314-5AE01-0AB0 and 6ES7314-5AE02-0AB0 are not supported.
Thank you for your help.
Unfortunately when I check the version of my CPU, I made a mistake with the one that is working.
So I have a CPU 314 IFM 6ES7314-5AE02-0AB0, and isn't compatible with the CP 343 - 1 Lean.
So, next question:
There is a solution to upgrade my CPU and make it compatible with my CP 343-1 Lean?
Exist any compatible communication processor?
Thank you for your support.
Hi, I am new to this forum. I am trying to get into the program offline of one PLC Fanuc GE 90-30. To see the program I downloaded the software...
532
Hi Guys. i have a one production line where is the processor is CompatcLogix L35e, and 2 DeviceNet Scanners. Today our electricians told me a...
1,645
Hi everybody. I´am a little new programing HMI. I know that is important make an alarm and event historian database, which will save the alarms of...
3,972
hey guys, im trying to integrate the project following this tutorial: Proceed as follows to integrate a WinCC flexible project in STEP 7...
6,152
Hello, Who knows where the hidden files evrsi.sys and 386swap.par are on the harddisk from Windows XP? I can not find these. I use RSLogix5...
9,570
