plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old January 11th, 2011, 01:20 PM   #1
Jack Schit
United Kingdom
Jack Schit is offline
WinnCC Flex OPC problem
I have added an OPC client to an existing WinCC Flex project.
Although I can see all the variables from the OPC Server it won't let me assign them to a tag. I suspect that this is because WinCC can't recognise what type of data each variable is. In the data type column for the OPC variables, it says data type unknown (at least I think it does as it's in German!). The data type from the OPC server is "Float" which should be compatible.
Any advice much appreciated as I'm out of ideas now!
Jack
Old January 11th, 2011, 01:45 PM   #2
JesperMP
Denmark
JesperMP is online now
JesperMP's Avatar
I cannot test it right now.
But try set the data type to REAL in stead of FLOAT.
__________________
Jesper
Old January 11th, 2011, 01:48 PM   #3
Jack Schit
United Kingdom
Thanks JesperMP,
I shall try this in the morning.
Jack
Old January 11th, 2011, 02:14 PM   #4
Jack Schit
United Kingdom
JesperMP,
Just a thought, does the fact that I can see the variables indicate that the DCOM settings etc are ok?
I'm using a Simatic Panel PC 677 and both the Server OPC and Client OPC (Wincc Flex) are running on this PC.
Jack
Old January 11th, 2011, 02:53 PM   #5
JesperMP
Denmark
JesperMP's Avatar
As far as I know, DCOM does not have to be setup when OPC server and client are both on the same PC.
__________________
Jesper
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
WinCCFlexRT OPC server connection problem idell LIVE PLC Questions And Answers 5 April 26th, 2010 09:58 AM
WinCC Flex Compiling problem Dutchi LIVE PLC Questions And Answers 5 March 10th, 2010 04:08 AM
Flex frequency input module - problem with encoder connection iknowsomeplc LIVE PLC Questions And Answers 3 October 30th, 2009 09:18 AM
Flex 1794-ie8 analog input module problem smsp LIVE PLC Questions And Answers 8 October 26th, 2009 12:08 AM
OPC Servers, Cimplicity problem pavel47 LIVE PLC Questions And Answers 3 July 27th, 2005 06:18 AM
