[WinnCC flex 2008]Run script automaticly in faceplate
lauwerstim
Apr 2006
Kontich
93
I've created a faceplate in WinCC flex 2008. I've written a script in it. I can run this script if I put a button in the faceplate that calls the script.
What I want however is that the sript runs automaticlly when the faceplate is visible. It should run only once.
I've tried adding a proprety to it. When the property changes value, the script is called. Then put a tag to it wich is changed from outside the faceplate. This however doesn't work.
Any ideas on how to run script automaticlly or from a command (button) outside the faceplate.
Thx in advance.
I've found the solution (thanks to the helpdesk in Germany).
I need to use an external tag to trigger the script. So I created a marker in the PLC and change the value of that when I need to load the script in the faceplate. Works like a charm.
Hi, I have just set up a trend view graph which monitors two temperatures. The log time will only let me view results as far back as 8 hours...
2,815
Hi everyone, i make a programm in WinnCc Flexible, and i have a question, i explain what i want to do: i have 6 buttons. when i press one of...
1,362
Hi, I have added an OPC client to an existing WinCC Flex project. Although I can see all the variables from the OPC Server it won't let me...
2,010
I'm new using Wincc FLEX and I would like to know how make a start button change it's color to green when staus changes from 0 to 1. I'm using an...
1,610
Is there a way to globally replace addresses on a Screen? I can't see a way to export the screen to modify in word, excel etc. I also can't see a...
1,467
