Winncc flex
h725john
May 2008
Greensboro
I'm new using Wincc FLEX and I would like to know how make a start button change it's color to green when staus changes from 0 to 1. I'm using an external push button connected to Siemens S7 PLC (input 0.0 output 1.1)
Thanks:geek:
Are you trying to animate the buttons color based on the input status or output status? You should be able to go into the appearence properties of the button and connect a digital (bit) tag to that animation. WinCC flexible is not real intuitive as there are different properties and check boxes that can affect animation. The button animation will also depend on what type of button you are using (momentary or maintained).
Hope this might help you move forward. Sorry if my comments are a little vague but I do not have the software in front of me right now.
Hi everyone, i make a programm in WinnCc Flexible, and i have a question, i explain what i want to do: i have 6 buttons. when i press one of...
1,359
Hi, I have just set up a trend view graph which monitors two temperatures. The log time will only let me view results as far back as 8 hours...
2,809
Hi, I have added an OPC client to an existing WinCC Flex project. Although I can see all the variables from the OPC Server it won't let me...
2,008
Is there a way to globally replace addresses on a Screen? I can't see a way to export the screen to modify in word, excel etc. I also can't see a...
1,465
I've created a faceplate in WinCC flex 2008. I've written a script in it. I can run this script if I put a button in the faceplate that calls the...
3,985
