plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old November 7th, 2013, 11:39 PM   #1
santisiah
United States
santisiah is offline
Newbie with a few questions
Hello all.. I am pretty new to programming PLC's and have a few questions. We are using Mitsubishi PLCs and HMI's and I am writing a new program. We have a lot of pumps and actuated valves we will be controlling so a lot of outputs. My question is, if we are using the internal relays in the program to control the 24VDC coils to the pumps, can I use M1 and continue with M's until whatever number I want or do I have to use the M's with Hexadecimal as I do with the outputs. These are only used for the push buttons on the HMI's and I don't have actual inputs from the "real world."
For example:
-||-, -||-, -||-, and so on..
M1 M2 M18
Hope you all understand what I am asking. Thanks for your help.
Old November 8th, 2013, 04:26 AM   #2
dploof23
United States
dploof23 is offline
Quote:
For example:
M1 M2 M18
Hello,
The M bits are decimal. You start at M0 and go up from there. Keep in mind, some M bits are reserved for special functions depending on the PLC type. If you look in the help menu you should find a list of special relays/registers by PLC type.
Hope this helps,
Dave
Old November 8th, 2013, 09:36 AM   #3
santisiah
United States
Thanks a lot Dave. I thought so but wanted to make sure with the experts here
Old November 8th, 2013, 10:47 AM   #4
Lancie1
United States
Lancie1 is offline
Lancie1's Avatar
Quote:
...Can I use M1 and continue with M's until whatever number I want or do I have to use the M's with Hexadecimal as I do with the outputs.
The underlined phrase indicates that you think your "Y" outputs are Hexadecimal. They may be grouped in 16-bit words, but each Output is normally used as a single bit of a certain 16-bit word. That applies to "M" Marker bits also. Only at rare times will you need to treat Y outputs and M bits as a group (when you want to reset all bits in a word to 0, or write the same value (1 or 0) in all bits of a word).
Old November 8th, 2013, 11:55 AM   #5
dploof23
United States
dploof23 is offline
Quote:
Lancie, I think what he is talking about is the addressing structure when programming Mitsubishi controllers. The inputs and outputs are addressed in hexadecimal, i.e. X0-XF, Y0-YF. The internal M bits used like the B3:0/1 type in AB are addressed decimally. Data registers are also decimal.
This varies by PLC type, the Q series is as I described above, but the FX I/O is addressed in octal. The M bits and Data regs are always decimal though.
Dave
Old November 8th, 2013, 04:59 PM   #6
Lancie1
United States
Lancie1 is offline
Lancie1's Avatar
Thanks for clearing up that he meant the address numbering system. Many older PLCs used octal and hexadecimal address numbering due to the limits of the old hardware.
Old November 10th, 2013, 09:59 PM   #7
santisiah
United States
Dave is correct in what I was asking. Lancie1 thanks for your response though. I really appreciate the help.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
rsview me newbie questions stallone LIVE PLC Questions And Answers 0 November 16th, 2010 06:12 AM
S7-Graph newbie questions MartinW LIVE PLC Questions And Answers 12 July 19th, 2010 08:40 AM
Newbie Questions sporkins LIVE PLC Questions And Answers 15 January 30th, 2009 12:48 PM
obvious newbie, have questions! stasis LIVE PLC Questions And Answers 7 March 3rd, 2005 08:37 AM
Newbie with questions. MontyMaccy LIVE PLC Questions And Answers 11 September 9th, 2004 02:53 PM
