FP-X pulse output and A4 series servo modbus address
yee4228
Nov 2013
lunas
PLC:FP-X relay type with pulse output cassete.
touch screen: GT32-T
Servo:A4 series
i plan to use pulse output cassete to control CW position and CCW position, and use modbus communica servo and PLC to view my servo position.
problem here:
-i try to use instruction F168 as home return function , but it popup message"Entered Instruction or device not supported with current type of PLC"
-pulse output cassete need any setup at FPWIN ?
-i saw manual of AFPX-PLS that is a message Inform :Y100-CW-PLS ; Y101-CCW-SIGN, mean Y101 cant control with pulse? What is mean SIGN?
-any one had manual of A4 series manual that had modbus address? i try to find address of parameter "00" of A4 servo .
Could you please help me??
Thanks for reading.
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
135
I have PLC Omron CJ2M with OD211 module. I want to use the pulse output and PWM output and this module. But i confuse how to activated this, i...
105
I am monitoring two BMXDDO3202K digital outputs for their behaviour, they are each for opening and closing, and so the on time affects how far the...
285
Hello, I am using pulse train output to a stepper driver to control a stepper motor. It seems to work fine except when I use a Control Stop...
3,324
Hi all, To make a long and annoying story short, a client has two flowmeters in their water plant and the flowmeter that controls the CL2 dosage...
2,334
