I wanted to quickly test an 0-10Vdc analog input on a plc, but I did no have a professional simulator close by at the moment. So I thought I could rig it using a 24Vdc power supply and a potentiometer. But it just refuses to work. I have the positive from the power supply running into the positive of the potentiometer. The wiper of the pot then goes to the positive of the analog input. The negatives just go together. But the pot makes absolutely no difference in the voltage. It is a 1watt, 5K pot and either the whole way down or the whole way up, the output voltage on teh wiper terminal measures the exact same as the power supply voltage, maybe with a difference of 0.02volts. I figured teh output from the pot should be 0-24V. I checked the pot with my Fluke ohmmeter and I have a good scale of 0-5000 ohms on the pot.
Can anyone give me any suggestions of what I am doing wrong?
