0-30v Analog Input
mad4x4
Mar 2009
ST CYrus
363
Any ideas on who to convert 0-30v to 4-20mA or 0-10v I know I can use a potential divider with a few resistors but need something that can be "Bought" and rail mounted rather than "made"
Need t get a 24v Battery condition signal into a PLC for monitoring over profibus. Only have spare 4-20mA analog inputs.
Just a simple resistor would get your 30v to 10v, not sure of the size you would need but I go from 0-24vdc to 0-10vdc all the time with a resistor, the size depends on what you are connecting to, mine range from 75 ohm to 300k
Not sure if loop powering them would be possible in your situation, but maybe look into Acromag's TT238. Multiple range (+/- 75VDC range in your case) DC voltage input, 4-20mA output.
Hi, I have 5 Parker IP66 VFDs, 3pcs 400V and 2pcs 230V. Two of them are located on a filtrating machine and three of them are located on a...
2,001
Hi everyone i know this can be done using a capacitor in paralel. My question is if there is any limit in the power of the motor to do this. The...
2,025
Hello all, Who have links for documentation,- how to connect Allen Bradley 3 phases VFD PF753 in test purposes using only 230V. Approximate...
1,559
Very simple question, can Power supply module PS 60W120/230V AC/DC(6ES7507-0RA00-0AB0) work on 100 V AC voltage? Basically can this power supply...
1,425
Folks, Where I work we have a 230V 1 phase supply and Motor is 3 phase 230V. We connect an ac single phase powerflex 70 and let it produce 3...
6,093
