0 TO 10 Volt convert Into 4 to 20mA
jcp
Feb 2010
Multan
369
Hi friends;
I have a PCB which give me 0 to 10 volt signal crossponding to the frequency which is 0 to 11520 Hz. Now here is my limitation started, I have ALG223 high density current module for the PLC 90-30 series. Is it possible to convert 0 to 10 volt into 4 to 20mA and connect to the ALG223.
Please guide me how i fix it? Post a circuit diagram if any one have. Thanks
Regards
You seem determined to make things as difficult as possible. The Red Lion model recommended in an earlier thread is field selectable for either voltage or current output. Knowing that you have a mA analog input module, why did you purchase a frequency/voltage converter instead of a frequency/mA? Can you get a IC693ALG222 analog voltage module instead of the IC693ALG223?
The published impedance of a channel on the module you have is 250 ohms. With an additional 250 ohms resistance in series, a ten volt signal will draw 20 mA.
try to find the resistor of 250 ohms, cut it and you will have a voltage input. 250 ohms is only 5 volts but when you take two resistors of about 10000 ohms you create a divider so when 10 volts coming out the input is 5 volts. just try it, if it does not work no worries just put the resistor back and buy a converter.
Dear All, 3 phases (380-400 volt) are needed for my small lap in my garage. Normally there is one 1 phase 220-230 volt in my garage but I would...
31
6,610
Can anyone recommend a flexible 600-volt shielded ethernet patch cable? I have used them from Allen Bradley / Panduit before and they are too...
111
Hello, I am very new to the plcs and am working on a project that requires a fixed mount barcode scanner to scan packages as they move along a...
200
Good afternoon, This one may sound crazy. I have a device that is configured to outputs a 0 to 10 volt signal. the scaling is 0 - 0 and 10 -...
1,657
We are installing 20 foot direct burial fiberglass light poles, and we are mounting speakers for a pa system on the pole about 12 feet up. Can the...
1,821
