10VFD control using TWIDO PLC TWDLCAA24DRF
b4umusic
Jan 2012
toronto
I am writing a program for Twido CPU using twido suite ver. 2.30 to control 10 vfd using Magelis HMI, VFDs are controlled by Macro Drives.
The problem is Executable memory usage goes 105% for the controller (TWDLCAA24DRF) when programmed for 10 vfd but if I delete configuration for one VFD than memory usage comes to 95%, Used Memory words are from %MW0 to %MW299 for Macro Drives and from %MW300 to %MW352 for other (not all used).
When Compiled it gives error of too much memory used and so cannot transfer to PLC even with 95% memory usage
If anyone figure out whats wrong and how it can be corrected than I can send a project file.
Thank you
Update
Thanks for replying, I am using TWDLCAA24DRF which doesn't support extended memory
Memory allocation problem in Twidosuite, I use Twido Soft and volla no problem at all, memory usage was properly calculated in Twido Soft , compiled program with no errors and progammed Twido controller without any problems
you can use advanced program with indirect addressing and instance data block despite using heavily data words .these ways of programming will save about 80% of your working memory despite using absolute addresses directly
I’m attempt to establish a communication between two simulator M580 CPUs, using a READ_VAR, I have two vitalization Windows 10 in VMWare and each...
47
Adding ethernet equipment to an existing panel that has none. We have some solid ethernet cables coming from other remote cabinets that I plan to...
124
does anyone have an install or know if/where i can download it for the following "ABB PS501 Control Builder Plus V2.3 " the software was a free...
90
I am not sure why this is requested, but it was asked. Currently I have one PLC , with one output to a relay, turning on a field equipment (just...
219
I have been requested to test this proportioning valve for PLC control of flow/pressure. Dwyer Series SVP Proportioning Solenoid Valve The flow...
422
