12 Hr Clock
When you reply, scroll down for additional options.
Click the Attach Files button.
Browse to your file and don't forget click the upload button.
seconds- cascade timers set to 5
AM/PM- LIM function 12-24 reading off an ACC from a CTU
used two CTU's counting 13 and 24. the one set for 13 is to jump back to 1:00 thru a EQU function. hope this helps. I'm stuck on rolling average's...
We recently purchased a IC693CPU352 module and it appears the internal time clock is static. I can set the time and date but once set it does not...
212
Hello. I cannot change the SendClock settings for a PROFINET IO device. I need to slow down the CODESYS PROFINET IO controller. What am I doing...
226
Hello everyone, I am not a programmer, but I can do some simple programming. So now I want the time to be recorded every time a pump turns on. I...
35
2,801
Hello, I am trying to create an AOI that will retrive the clock datetime bits from a master plc through a generic message read instruction and...
524
I was online a SLC5/04 yesterday and one thing I did was go to processor properties and set the date and time to get the PLC clock current. It...
747
