12 Volt Operating voltage
plcBen
Jun 2009
Tennessee
I am trying to select a PLC that uses the RSLogix500 programming software that operates on 12volts DC. Also, I have RL Linx Lite vers. 2.41 I have a Microogix 1000 that works great, but I need something that works on 12VDC.
Thanks for the responses-
When RS Logix 500 software starts a new file, the list of processor types does not include the Micrologix 1100. It has the option for Micrologix 1000, 1200, and 1500. Does that matter? Which processor type should be selected?
Looks like you need a newer version of RS Logix. The 1100 is fairly new and older versions of software do not support it. Do you have a support contract with Rockwell?
Thanks,
I will try to get the newest version. Our management of license is in transition due to recent re-staffing, so I'm not sure if we can get an update or not. Thanks for the response--I've been away for a while [late response].
In viewing other posts, I think this is quite a common question (12volt DC power requirements). It appears that there are several options: Pico, Directlogix, ML1100 (mentioned here). Of these, does anyone know which ones of these have free software?
Can anyone recommend a flexible 600-volt shielded ethernet patch cable? I have used them from Allen Bradley / Panduit before and they are too...
114
Hello, I am very new to the plcs and am working on a project that requires a fixed mount barcode scanner to scan packages as they move along a...
205
Good afternoon, This one may sound crazy. I have a device that is configured to outputs a 0 to 10 volt signal. the scaling is 0 - 0 and 10 -...
1,660
Dear All, 3 phases (380-400 volt) are needed for my small lap in my garage. Normally there is one 1 phase 220-230 volt in my garage but I would...
31
6,690
We are installing 20 foot direct burial fiberglass light poles, and we are mounting speakers for a pa system on the pole about 12 feet up. Can the...
1,831
