12 volt PLC
Risleydesigns
Nov 2008
Kentucky
I'm looking for a PLC that runs on 12 volts that I can put on a modified push mower, that I can program to mow my yard. Does anybody have any suggestions of which PLC I should use?
[font=Arial, Helvetica, sans-serif][size=-1]Moeller easy relay might be the cheapest solution
512-DA-RCDA-RCX[/size][/font]
Sir,
All of our controllers can operate at 12 VDC. Much will depend on your requirements as to which controller would best fit your application. www.entertron.com
Based on the brief information you had provided, probably the Smart-PAK series would suffice. www.entertron.com/smart-pak.htm
You will require software for programming. Some of the previous listed options provide software but there will be a cost. Some offer free software, but there is a limit to the size of the program you can create.
You can download our programming software. It is free of charge, but password protected. You will need to complete the form below to receive a password. www.entertron.com/software.htm
www.entertron.com/form.htm
If you would like to discuss your requirements in greater detail, feel free to contact us through the information on our web site.
Hope this helps.
God Bless,
Nate W said:
The Horner XLT series of devices, operate on 10-30V. They also have a built in HMI and I/O.
The Horner XLe may be a cheaper option, 12VDC and LCD display with function buttons and such as an altrative to the XLt.
I saw one of these mowing a guys lawn in Missoula a couple of years back.
Pretty cool.
RoboMow
Has anyone ran across a card reader besides the RFIDEAS 5-9v card readers? I need to install 4 HID readers that I can tie into my PLC and...
2,242
This has thrown me a curve ball so I'm looking for someone smarter than myself to provide me an answer. I have a 24 Volt 1769-OB16 DC output card...
4,299
Does anyone know of a PLC that will run on 12 volts DC? Rockwell's Pico line has a 12 volt unit but I need something comparable to the Micrologix...
17
15,647
Can anyone recommend a flexible 600-volt shielded ethernet patch cable? I have used them from Allen Bradley / Panduit before and they are too...
113
Hello, I am very new to the plcs and am working on a project that requires a fixed mount barcode scanner to scan packages as they move along a...
205
