1203-SM1 Scanport configuration
rrparker07
Jun 2010
Winston, GA
89
Possible dumb question alert here. Is the 1203-SM1 module for Scanport communication "plug and play" as long as the DIP switches are set properly? The manual I pulled up had instructions for configuring the card with Advanced Programming Software which from the screen shots, looks like a predecessor of Rslogix 500. Thanks in advance,
Roy
The basic functionality of the 1203-SM1 is pretty simple, but sending messages to read and write drive parameters other than start/stop/speed/feedback is moderately complicated.
It goes all the way back to APS ? That's old-school !
Some of the complexity will come from whatever network you use them on. The APS instructions probably refer to RIO and the 1794-ASB, but these modules should work with any FLEX adapter, including DeviceNet and EtherNet/IP and even the old FlexLogix or DriveLogix controllers.
Sorry for the late response...snowed in. I may not have been clear in my question. I'm not making any changes to the program. I just need to know if I buy a spare module, do I simply change the module out if the one in the rack should fail? In other words, do the same process I would if an input card failed?
Hello Upgrading to a ControlLogix processor using existing 1746 I/O (If it ain't broke why fix it?) Main Rack 0 - 13 Slot Chassis Expansion...
2,687
Hi all. I am currently on a project or updating a panel with a slc 5/04 processor controlling 3 1305 drives via a 1203-sm1 SCAN Port. The company...
2,279
so the 1203-sss is a DPI device, the 1203-USB says it will do DPI/DSI. is the 1203-sss capable of communicating with the devices using DSI like...
1,462
Is anyone else having looooong connecting times when using CCW to a 750 via a 1203-USB? It is taking upto 10 minutes to connect to drive or...
1,793
we have 12 numbers of power flux 40 drives in our system placed in the devicenet network. I want to connect with DSI port of power flux 40 to see...
3,893
