1203-SSS vs Drive PF755
DanteLuciano
Jan 2015
Monterrey
Hello guys, how are you?
I´m trying to conect a PowerFlex drive 753 with a 1203-SSS cable, but I get some errors with RSlinx Classic. I add a image showing the errors.
I put the following parameters in the configuration dialog box:
Comm Port: Comm port on your PC
Device: 1770-KF2/1785-KE/SCANport
Baud Rate: Baud Rate of the Adapter
Station Number: 00
Parity: None
Error Checking: BCC
Stop Bits: 1
Protocol: Full Duplex
Station Number: 00
Parity: None
Error Checking: BCC
Stop Bits: 1
But the RSlinx say a error "rslinx device not recognized", and the CCW can´t conect with the device, just not appears in the options.
Can you help me?
Station Number: 00
Parity: None
Error Checking: BCC
Stop Bits: 1
Station Number: 00
Parity: None
Error Checking: BCC
Stop Bits: 1
Can you help me?
Hello, can you solve the problem??
Hi, as mentioned by alan_505, autoconfiguration is not supported for 1203-SSS.
However, here is a working configuration from my PC:
Baud Rate: Baud Rate of 1203. By default 19200, if I am right
Station Number: 00
Parity: None
Error Checking: BCC
Stop Bits: 1
Hello, I got a 1203-SSS and use that to connect to my PC (DriveExecutive and RSLINX OEM 2.50.02 installed) and the AB drive (1336-PLUS II, and...
11,875
so the 1203-sss is a DPI device, the 1203-USB says it will do DPI/DSI. is the 1203-sss capable of communicating with the devices using DSI like...
1,460
Is anyone else having looooong connecting times when using CCW to a 750 via a 1203-USB? It is taking upto 10 minutes to connect to drive or...
1,789
we have 12 numbers of power flux 40 drives in our system placed in the devicenet network. I want to connect with DSI port of power flux 40 to see...
3,892
Hi all. I am currently on a project or updating a panel with a slc 5/04 processor controlling 3 1305 drives via a 1203-sm1 SCAN Port. The company...
2,277
