1203-USB converter driver
unsaint32
Oct 2012
minneapolis
365
I am trying to use 1203-USB converter for my Powerflex4 with Connected Components (version 10.01).
I downloaded the instruction from Rockwell about 1203-USB Converter. https://rockwellautomation.custhelp...alling+USB+Drivers+for+1203-USB+Converter.pdf
Here is what it says... "If you intend to use Connected Components Workbench software, version 2.x.x or later, to configure the converter and connected drive, these two USB drivers are automatically installed during the installation of this software." The "two USB drivers" are USB converter driver and USB serial port driver.
So I am thinking, since I already have CCW 10.01 running in my laptop already, all I have to do is to plug in the converter and I should be ready for adding drive to RSLinx.
But below is what I see.. after I plug in the USB converter.
So, is the document wrong about "automatically installed?" Does it mean it's been downloaded but I have to find and install them?
I had to install a driver separately. Think I searched for that p/n under firmware downloads or something.
we have 12 numbers of power flux 40 drives in our system placed in the devicenet network. I want to connect with DSI port of power flux 40 to see...
3,897
please help me dear everybody I'm not yes 1203-USB converter cable, types: 1203-USB converter cable connecting for Guardmaster MSR57P Speed...
2,968
Has anyone had experience running a 1203-USB Converter from Allen-Bradley on Windows 7 64 bit? I'm able to install the drivers on XP Pro 32 bit...
11,175
so the 1203-sss is a DPI device, the 1203-USB says it will do DPI/DSI. is the 1203-sss capable of communicating with the devices using DSI like...
1,462
Is anyone else having looooong connecting times when using CCW to a 750 via a 1203-USB? It is taking upto 10 minutes to connect to drive or...
1,793
