120PSI Panel Mount Pressure Switch
Doug4329
Jan 2018
Mississippi
Company wants a digital pressure switch panel mounted in a 8x8x6 enclosure on a machine, near where the operator stands for ease of adjustment. The enclosure will also have two 120v indicator lights. They want lights and pressure switch to be door mounted. I have seen many vacuum switches panel mounted but never a 120psi mounted in a panel with 120v and never seen one door mounted. The enclosure has a side hinged door that will swing open. Is this practical to do? How do I plumb the pressure switch so that it can swing open with the door? Thanks
Could you elaborate, you say a pressure switch do you mean a pressure indicator or a controller i.e. digital readout with adjustment it seems a bit vague.
The choices are:
Just an indicator
Indicator/controller
Indicator with digital set point.
if it is just a reading then I suggest the pressure transducer be replaced with a unit that gives 4-20ma out & an electronic indicator/switch mounted on the panel,
Is there anyone who can help me regarding this HMI is missing the choices when I make a new Device in TIA. Only 7" Display above are the choices...
81
I have a German programed ME program. I want to know what tag in the PLC a latched button turns on. However when I open up the tag properties I...
207
We are considering dropping our UL membership because most of our customers do not care if we are a 508A shop. However, there may be times when a...
396
Hello, I need to create an automatic transfer panel that connects to the generator when the mains power is cut. I can draw up to 60kW and draw up...
86
Am asking if we can upgrade sd ram and cf card of panel view plus ab by a normal sd ram and cf card but Allen Bradley to save cost because in ab...
281
