120VAC Fan controlled via PLC suggestions
If the heat is not too bad you could put 2 fans inside the panel, one on the left pointing up and one on the right pointing down, to circulate the air around inside the panel, on a site I used to go to had this arrangement in their panels that were mounted next to aluminium moulds that were at about 177 deg F (from memory or they could have been 170 deg C).
This way the whole panel was at the same temperature and they did not hev to put air conditioners on the panels.
Alan.
There's no need to guess about the right cooling method. Rittal, Hoffman, etc. have methods in their catalogs for calculating the heat load and cooling capacities of a system. You can also get tech support from the enclosure manufacturers to assist you.
And Racer's caution about the sun is well taken - a sun shield can make a huge difference.
Preface: Kinda long, so I made section titles Intro: I just want to see if anyone here has seen anything similar. A PLC5-40 series C enhanced...
367
Hello all, I have a relay timer connected to an Allen Bradley 1756-OA16I output card. The output was on, but instead of getting 120VAC we only...
829
the age old question / issue a friend has bought a 1000watt 120vac 60hz rated appliance from the USA into Australia (which has a 240Vac 50Hz...
2,447
by spec i must supply surge protection for each individual PLC input in my panel. These devices are all of the voltage free (dry contact type)...
2,245
Good afternoon, I have an application where we induction harden different areas on our assembly part using coils that wrap around and heat up to...
3,721
