140o to 1500
Tryingtolearn
Jul 2020
south australia
hi i have a failed micrologix 1500 and was just wondering can I upload program to a microlgix 1400 and just swap input and outputs over or is there a difference that i am missing thank you
Upload the program from the 1500 if you dont have it, save it so you still have a back up... now on the program tree select your 1400 CPU and check for errors, if they are both the same voltage, example both end in BWA then you should be able to download to the 1400, if one is a BXB and the other is a BWA then you will need to change your wiring
You are welcome, let us know how it works out and if you have any issues... we all have done it many times and someone should be able to help.
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
93
99
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
111
Hi all Trying to remotely connect to a TIA Portal PLC. I can ping it without a problem but can't get my software to connect. I've opened port...
348
Been fighting all morning with a stubborn HMI. It just won´t connect with the plc. attaching from settings. Have i missed anything? Both plc and...
311
