1734-232ASC capability and purpose of 1734-ARM
TheWaterboy
May 2006
-27.9679796,153.419016
1,927
This is my first L1 project so I am just getting a feel for the thing. I'm thinking the ML1400 is getting long in the tooth so this is the next logical progression.
Can the 1734-232ASC module be used for radio telemetry serial comms using common MSG logic or is this not that sophisticated a module? The docs say its for Barcode readers etc. so I expect its more of an AWT type of control. If not, Is there a serial interface that would work for serial comms on the L1? Like 24VAC I/O modules, I can't locate one.
And what on earth is a 1734 ARM (Address Reserve Module) used for? Its described as an address placeholder, but why would you ever need such a thing? perhaps the ability to add Optional features in a machine without having to modify the code? i.e. remove the ARM and put in whatever module the option needs?
The 1734-ARM was more important on network connections (especially DeviceNet) where mapping data was harder than just changing Slot numbers.
It simply takes up a Slot number on the POINT data bus, so that when you add a module later the other Slot numbers don't shift over and have to be re-addressed. It's generally used by OEMs who want a consistent wiring diagram and consistent addressing.
You've identified RS-232 serial communications as one of the weak points of the CompactLogix family. The 1734-xxxASC modules are made for simple ASCII strings and don't communicate over DF1.
There's a Prosoft module based on the -232ASC that will do Modbus RTU Slave, but not DF1.
I'm not sure if a 1761-NET-ENI or a Digi One IAP would serve your purposes with the CompactLogix. It's worth talking to Rockwell and Digi about.
Hello Friends I have took the sample program from AB webpage and modified, but I can only send 127 chars...
188
Does anyone know how to inhibit the 232 module from sending data during PLC power-up? To send data during normal operation, the Transmit Record...
1,908
Having issues sending numeric display to Vorne 87-705-4D-4CTR scoreboard from 5069-L310ERMS2 with 1734-232ASC. I have Putty up on one of the...
2,558
Hi All, I'm trying to connect a 1734-232ASC to a ViewMarq overhead display and I cannot figure this out for some reason. I have the baud rate...
2,057
Hello all, I have a 1734-232ASC that was working and correctly transmitting data. All LEDS were solid green and TX,RX were flashing green. I...
1,408
