1734 Analog Input Card Problem or Normal
emiller
Mar 2013
Sault Ste. Marie
Hello,
I have just installed an 1734-IE2V Point IO Analog Input Card and calibrated it. I used ground for the low reference and a DC source set to 10V for the high source.
I then disconnected the wires and with no input to the card it (open circuit) it is reading 10599 in Logix5000 and with a multi-meter between the leads it shows around 4VDC.
Is this normal because there is nothing connected to the card or should it go to zero when nothing is connected to the input?
Hello,
Did you get to solve this issue? I have a 1734-IE2V and I'm not getting any measurement. I've checked the wiring several times and I know it's correct. Now, when I use a multimeter to check the lines I see that it reads 5VDC, but the module always shows 0. Also, the status bit 2:I.ChData.0 ("fault" bit) is true, and it's the only status bit that is true.
I don't know if this was exactly the issue with you, but I think it might be similar. I'm not sure what could be the cause though.
Jose
We have a Rockwell 1734 IE8C 8 channel analog input card, but we don't know if this is sourcing or sinking. The user manual doesn't seem to have...
1,135
I ran into a strange issue the other day. System has been up and running for many months. An analog input channel suddenly reported 0mA. I...
21
3,336
Hello all, I have attached a video in which the 2 point analog input flashed red for a sec/ The one marked with yellow name sticker.It is scaled...
3,269
We had encounter a problem regarding on our Allen Bradley 1734-IE2C, When we connect 1734-IE2C, to CompactLogix (L18ER), the PLC does not...
4,895
I'm using the point I/O analog input module with a 1769-L16ER-BB1B controller. In the module properties the high engineering and low engineering...
1,706
