1734-IE2C analog input module
technolog
May 2015
Ohio
320
I'm using the point I/O analog input module with a 1769-L16ER-BB1B controller.
In the module properties the high engineering and low engineering are set at 16383 and 3277 respectively, the filter value is 0 and the range is set to 4-20mA.
What value would I see in the PLC in the event of an open circuit? 0 or 3277?
The counts you will see are going to be very low. They may not go to zero but will be significantly bellow your 4mA 3277 scaling.
We had encounter a problem regarding on our Allen Bradley 1734-IE2C, When we connect 1734-IE2C, to CompactLogix (L18ER), the PLC does not...
4,895
I must be missing something simple here but this is driving me nuts. The setup is a Point IO rack with a 1734-IE2C Analog Input module. The rack...
4,127
Hi all, This is my first time working with a 1734-IE2C analog module. I am tasked with wiring the flow meter into the analog card and the OEM is...
173
I am running out of real estate in my panel. I have several IE2C cards. I would like to convert them over to IE4C to create space. Rockwell...
1,350
Hello people, I have a 1734-IE2C module which reads a valve position. When the valve is 100% opened the channel data value is something about...
2,280
