1734-arm Module Profile
Shosh
Jul 2013
North Carolina
I have a 1734-ARM card on a point IO rack. Do you need to add this card on the module list in your PLC program? Running RSlogix 20.04 and cannot find the card on my module list, nor can I find a module profile on Rockwell's website.
The key sentence from that thread:
The ARM just reserves a node address/slot for a future I/O module and is not selectable under the I/O Configuration in RSLogix 5000. So you add the future intended module to that slot and then Inhibit it. This stops the controller from continually trying to connect to a module that is not communicating because it does not exist, potentially wasting connections.
If you don't know the future intended use, you can set it up as a 1734 generic module. Then just give it a name like ARM-SPARE1
For generic setup you can use:
Data-SINT
Input 1 1
Output 1 1
Configuration 1 0
hello,I have a project used the 1769-SDN module ,the 1769-SDN address is 0,the 1769-SDN is alarm ,the alarm code is 78 and 1 address.under the...
2,632
Hi, Could you please explain me what 1734-ARM (ADDRESS RESERVE MODULE) is used for exactly? I have read the Rockwell Manual but did not get my...
2,229
This is my first L1 project so I am just getting a feel for the thing. I'm thinking the ML1400 is getting long in the tooth so this is the next...
1,579
Hi everyone, I have a AENT-R that I need to change the I/O structure around in due to customer changes in the cell. Instead of re-labeling all...
1,856
Looking at installing point io, with a 1734-AENTR communications adapter and ten 1734-IT2L modules. In IAB it installs a 1734-EP24DC after every...
67
