Hi All,
I have a Devicenet network installed, configured, and working properly. One location in the network consists of the following: 1734-PDN, 1734-OB4 (Node1), 1734-IE2C (Node2), 1734-OE2C (Node3), 1734-OE2C (Node4), 1734-OE2C (Node5), 1734-OE2C (Node6), 1734-OE2C (Node7), 1734-IT2I (Node8), 1734-IT2I (Node9), and 1734-IT2I (Node10). I have physically removed 1734-OE2C (Node7) from the 1734-TB wiring module (to be replaced later) leaving an open slot. SDN showed Node7 was code 78 (as expected). Power has been cycled to the control cabinet (but not 24V Devicenet power), SDN still Node7 code 78 and all else still functional. Cycle power to PLC (1768-L43 utilizing a 1769-SDN Devicenet module and Right End Cap) Node7 code 78 and all still functional. Called it a night. Returned next morning to find Node 8 (1734-IT2I) is now Node 7, Node 9 is now Node 8 and Node 10 is now Node 9. I forgot to check status on SDN module. Keep in mind there are two programmers (me and one other) using the same PC, RSNetworx configuration file and RSLogix5000 program. ADR is NOT configured and NOT enabled nor is AAR enabled in the 1769-SDN. Any reason these nodes are changing addresses because of a missing module in the middle ?
Thanks in advance,
Thanks in advance,
